Change "Implicit Mesh Update Interval" using UDF
Old   December 30, 2014, 05:52
Default Change "Implicit Mesh Update Interval" using UDF
Anders Simonsen
ASimonsen is on a distinguished road
Hello.
I'm currently simulating a falling plate, where I've written a UDF to integrate the forces on the plate and updating the velocity of a dynamic mesh zone. However, as the velocity (and acceleration) is dependent on the flow, I'm using the "Implicit Update" option, where the "Update Interval" can be defined.
My problem is that it takes a long time for Fluent to execute and update the mesh at each interval, so I want to be able to change the "Update Interval" within a time-step using my UDF. For instance - I'd like to have it to update the velocity at iteration 1,2,3,4,5 , 10 , 15 , 20 , 30 , 40 , 50. So the update interval would be changing within a time-step. Is this possible?
Thank you in advance!
Anders
ASimonsen is offline   Reply With Quote
Old   May 28, 2017, 16:52
saurabh kumar gupta
rsaurabh is on a distinguished road
I am simulating blood flow through mechanical heart valve. I am using fluent and utilizing implicit update. When I am not selecting implicit update, my dynamic mesh is failing. But with selecting it, case is running file.
So I wonder if you can elaborate a little bit about it what you have got to know by your experience.
Any help will be appreciated.
Thanks and regards
Saurabh
rsaurabh is offline   Reply With Quote
Old   October 12, 2017, 09:38
志新高(Zhixin Gao)
zhixin is on a distinguished road
Originally Posted by rsaurabh View Post
Thanks and regards
Saurabh
Hi, I am doing the similar fluid flows through MHV, when I use SDOF and implicit update, it can run, but when I use DEFINE_CG_MOTION macro, it seems the case fails. However, I don't know how to restrict the move of the leaflet using SDOF. can you tell if you use the SDOF or your own UDFs?
Tanks!
Zhixin
zhixin is offline   Reply With Quote
dynamic, implicit, udf
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Can't Update FLuent Setup with active Connections in Mesh dulka90 FLUENT 8 December 9, 2013 11:36
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
