September 2, 2014, 22:42 |
Divergence with source UDF for VOF
Rep Power: 12 |
Hi everybody
I wrote an UDF for sources (lift, drag, virtual mass forces and K and epsilon) for VOF model two phase(steel and injecting argon). the simulation converged without sources but when the source became activated the simulation diverged suddenly after 1.5 sec with this error:sweeping relaxation factors, divergence in X momentum y momentum, z, k , epsilon- divergence detected in AMG solver: x-momentum', floating point exception . Global Courant number was stable before divergence. I did the following procedures: 1- limiting the sources to just above argon inlet and below the free surface 2- changing the URF of sources from 0.1 to 0.05 but still diverging suddenly. I really dont have any idea whether it is a structural error in sources or errors in setting of fluent. Much appreciated if anybody help me to find the error. |
September 3, 2014, 01:51 |
Rep Power: 15 |
Since you mentioned that it worked without the source term, something might be wrong with the source term calculation. If you share your UDF with a short description, I'll have a look. The "floating point exception" error usually happens due to a bad math throughout the code such as division by zero or some variables go to infinity and etc.
September 3, 2014, 06:51 |
your email
Rep Power: 12 |
Dear SUN
I would be appreciated if you give me your email. I would send my UDF to you. Thanks in advance |
September 3, 2014, 10:55 |
Rep Power: 15 |
You can send it via private message.
December 28, 2014, 01:16 |
Rishitosh Ranjan
Rep Power: 13 |
I m also facing same prlm...
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
help on UDF mass source | shao1 | FLUENT | 2 | July 11, 2002 20:36 |
