how to use UDF with cylinderical coordinate system in fluent
Hi my friends,
i am working on plasma distribution problems, and it is more convenient for me to written the set of equations and boundary conditions in cylindrical component form, but as far as i knew, fluent only has Cartesian coordinate system so how should i do to put the cylindrical component form into UDF and use them in fluent? I am desperate for your help~ |
Can you provide more details on the nature of equations? Meanwhile, have a look at this doc, a nice summary of field variables/functions in Fluent. You might be able to find most of the access functions you need. hope it helps. cheers! |
3 Attachment(s)
Thanks for your replay, my friend.
it is in the paper titled "2D expansion of the low-density interelectrode vacuum arc plasma jet in an axial magnetic field",with a 2D MHD model, but the energy equations are not considered.The pdf is too large to upload.~ i wonder whether the equation set 3 can be calculated in fluent. And you can see, the self magnetic field Bθ is more simple to express in cylinder system~ Quote:
Peter,
Unfortunately, I don't have access to the full paper. But Looking at Eqs. 3.1 to 3.6, you need to convert the Cartesian velocities into axial, radial, and tangential ones. I've googled around a bit and stumbled upon these slides. On slide 34 and 35, you'll find a way to convert the velocities. However, I am not quite sure if you can use the very same approach for other terms in the equations. It might be a bit tricky. cheers |
Thanks my friend, i got what you mean by the slides, use Cartesian in fluent while use cylinder system in UDF.
It is a bit tricky to me, but i will try two ways, to take the same approach in the slides, or just convert the basic equation set 2 into Cartesian system, and the tangential component has to be divided. BTW, the original auther of the paper didnot use fluent to calculate, insead they program themselves:) |
Hi, Sun,
I think if it's a 3D model in Cylinder Coordinate, it can't directly be used in fluent, because the momentum components are written as Vx,Vy,Vz in fluent.As a consequence, the source terms in the momentum equation can't directly be used from Cylinder to Cartesian. But my problem is a 2D axisymmetric model, the z and r component in the figure just equals the x and y component in Cartesian, the only difference is the tangential component vs y compenent. I think this may be done by the approach you told me. I would give it a try |
Alright great and thanks for the update. I guess that method might actually work for the 2D case.
good luck. |
