F_UDMI - Does it work or not?
Old   February 2, 2015, 13:45
Default F_UDMI - Does it work or not?
Rui_27 is on a distinguished road
Hello to everyone,
My question is simple: Does the F_UDMI work?
I first faced this problem a few months ago in Fluent 14.5.7. I did managed it by using C_UDMI function instead.
I just moved to Fluent 15.0.0 hoping that F_UDMI would work in it, but no...
C_UDMI does the job well, but in my case I really would like to use F_UDMI, because CFD-post only displays node values and not cell values. And for a face, nodes values are quite different from cell values...
Please share your experience using F_UDMI.
Regards,
Rui
Rui_27 is offline   Reply With Quote
Old   March 5, 2015, 22:10
`e`
`e` is on a distinguished road
What variable are you storing with F_UDMI and does it make physical sense to do so? Faces may attach to one or two cells depending on their type (boundary, interior, walls etc) which could complicate things.
`e` is offline   Reply With Quote
RP_Set_Integer does not work in parallel 86lolo Fluent UDF and Scheme Programming 2 July 3, 2014 11:37
Does CX_Interpret_String work in parallel? 86lolo Fluent UDF and Scheme Programming 2 June 30, 2014 04:36
Companies that lease software & hardware for cloud-based work? Catthan ANSYS 0 June 18, 2014 10:53
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
