February 14, 2015, 17:26 |
porosity udf
walied
Rep Power: 11 |
hello every body
i made a UDF for anode and cathode porosity in the SOFC module, but the energy residual get the following reading 1.#QNBe+00 PLEASE URGENT HELP....... here is my UDF #include "udf.h" /**********************Anode Porosity **************/ DEFINE_PROFILE(anode_porosity, thread, np) { cell_t c; real x[ND_ND]; real y; begin_c_loop (c,thread) { C_CENTROID(x,c,thread); y =x[1]; F_PROFILE(c,thread,np) =((y-1.53)/0.02)*(1-((y-1.53)/0.02)); } end_c_loop (c,thread) } /*********************Cathode Porosity*****************/ DEFINE_PROFILE(cathode_porosity, thread, np) { cell_t c; real x[ND_ND]; real y; begin_c_loop (c,thread) { C_CENTROID(x,c,thread); y=x[1]; F_PROFILE(c,thread,np) =((y-1.53)/0.02)*(1-((y-1.53)/0.02)); } end_c_loop (c,thread) } |
February 16, 2015, 12:04 |
Rep Power: 12 |
Take into account the following:
- Remember the units given by UDF are meters - The values of porosity must be 0-1. - You must set an appropriate value for Ri and Rv |
February 16, 2015, 13:55 |
walied
Rep Power: 11 |
thank you upeksa for your kind reply.
but what do you mean by Rv and Ri regards |
February 17, 2015, 04:11 |
#4 | |
Rep Power: 12 |
Check this post http://www.cfd-online.com/Forums/flu...us-medium.html Looking at your UDF, nothing seems wrong with your code. The error you get must have something to with some number out of range, so I think that the values of porosity you retrieve are higher than 1 or lower than 0. Cheers |
February 17, 2015, 14:34 |
walied
Rep Power: 11 |
hello upeksa;
thank you for your kind reply. please can you check the following udf for any error.i compiled it without any problems but i need to know is it right as a writing........ . #include "udf.h" #include "math.h" /************************************************** CONSTANT****************************************** *************/ #define m 1 #define rua 1.2 #define thermal 0.0242 #define anode_density 4760 #define electrolyte_density 1980 #define anode_ca 377 #define ca 1006.43 #define electrolyte_ca 2000 #define anode_THER 11 #define electrolyte_THER 2 #define cathode_density 4640 #define cathode_ca 377 #define cathode_THER 2.37 /************************************************** Anode Porosity****************************************** ********************/ DEFINE_PROFILE(Anode_porosity, t, i) { cell_t c; real x[ND_ND],y; begin_c_loop(c,t) { C_CENTROID(x,c,t); y=(x[1]*1000-1.56)/0.7; C_PROFILE(c,t,i) = pow(y,m)*(1-pow(y,m)); } end_c_loop (c,t) } /*************************************************C athode Porosity****************************************** ************************/ DEFINE_PROFILE(Cathode_porosity, t,i) { cell_t c; real x[ND_ND],y; begin_c_loop(c,t) { C_CENTROID(x,c,t); y=(x[1]*1000-1.5)/0.05; C_PROFILE(c,t,i) = pow(y,m)*(1-pow(y,m)); } end_c_loop (c,t) } /*************************************************A node Density******************************************* *********************/ DEFINE_PROPERTY(A_Density, c,t) { real va, ve, p, d, u, y, x[ND_ND], dens, POR, po; C_CENTROID(x,c,t); y = x[1]; u = (y*1000 - 1.56) / 0.7; va = pow(u, m); /* ve is the electrolyte material volume fraction*/ POR = C_POR(c,t); ve = 1 - (va+POR); /* va is the anode material volume fraction*/ po = va*anode_density + ve*electrolyte_density; dens = po*(1 - POR) + rua* POR; return dens; } /*****************************************Anode thermal conductivity************************************** ***********/ DEFINE_PROPERTY(A_THER_cond,c,t) { real va, ve, p, d, u, x[ND_ND], POR, A, B, D, G, Lo,R,T,H, y, termal_cond_anode; C_CENTROID(x,c,t); y = x[1]; u = (y*1000 - 1.56) / 0.7; va = pow(u, m); POR = C_POR(c,t); /* va is the anode material volume fraction*/ ve = 1 - (va+POR); /* ve is the electrolyte material volume fraction*/ A = (3 * (anode_THER - electrolyte_THER)*va); B = (3 * va*electrolyte_THER + (anode_THER +2* electrolyte_THER)*(1 - va)); Lo =electrolyte_THER*(1+( A / B)); D = Lo*(Lo*(1 - pow(POR, (2 / 3))) + thermal*pow(POR, (2 / 3))); R = (pow(POR, (1 / 3))*thermal); T = (1 - pow(POR, (1 / 3)))*((1 - pow(POR, 2 / 3))*Lo); H = (1 - pow(POR, (1 / 3)))*(pow(POR, (2 / 3)))*thermal; G = R + T + H; termal_cond_anode = D / G; return termal_cond_anode; } /********************************** CATHODE_DENSITY ************************************************** ******/ DEFINE_PROPERTY(C_Density, c,t) { real va, ve, p, d, u, y, x[ND_ND], dens, POR, po; C_CENTROID(x,c,t); y = x[1]; u = (y*1000 - 1.5) / 0.05; POR = C_POR(c,t); ve = pow(u, m); /* va is the anode material volume fraction*/ va = 1 - (ve+POR); /* ve is the electrolyte material volume fraction*/ po = va*anode_density + ve*electrolyte_density; dens = po*(1 - POR) + rua* POR; return dens; } /****************************************Cathode thermal conductivity************************************** ************/ DEFINE_PROPERTY(C_THER_cond, c,t) { real va, ve, p, d, u, x[ND_ND], POR, y,M,K,P,W, Lo,U1,J, termal_cond; C_CENTROID(x,c,t); y = x[1]; u = (y*1000 - 1.5) / 0.05; POR = C_POR(c,t); ve = pow(u, m); /* va is the anode material volume fraction*/ va = 1 - (ve+POR); /* ve is the electrolyte material volume fraction*/ M = (3 * (-cathode_THER + electrolyte_THER)*ve); K = (3 * ve*cathode_THER + (2 * cathode_THER + electrolyte_THER)*(1 - ve)); Lo = cathode_THER*(1+(M / K)); P = Lo*(Lo*(1 - pow(POR, 2 / 3)) + thermal*pow(POR, 2 / 3)); J = pow(POR, 1 / 3)*thermal; U1 = (1 - pow(POR, 1 / 3))*((1 - pow(POR, 2 / 3))*Lo); W = (1 - pow(POR, 1 / 3))*(pow(POR, 2 / 3))*thermal; termal_cond = P / (J + U1 + W); return termal_cond; } |
UDF for writing porosity as a function of distance from the wall | rohinibc | Fluent UDF and Scheme Programming | 5 | August 8, 2012 08:16 |
UDF for porosity | cfd-novice | FLUENT | 2 | August 20, 2009 03:19 |
UDF for porosity | Giacomo | FLUENT | 3 | July 23, 2007 09:23 |
UDF for orous zone porosity | ap | FLUENT | 2 | November 10, 2004 18:26 |
Macros for writing UDF for porosity | umesh | FLUENT | 1 | June 13, 2003 04:20 |
