UDF problem
Old   March 9, 2015, 07:12
Default UDF problem
Brian
qwe2077 is on a distinguished road
I'm a user of fuel cell addon-module, and I'm trying to get volume averaged relative humidity. and I got an error form my customized code.
My code was compiled well but when it stared to calculate, error came up.
I think the reason of the error was C_YI(c,t,i_h2o). When I deleted this term, there was no error. Can't it be used below begin_c_loop macro??
or Is dimension wrong? please help me!
below is my code
real Membrane_Conductivity(real lam, cell_t c, Thread *t)
Domain *d;
real volume;
real vol_tot = 0.0;
real P_sat;
real C_h2o = 0.0;
real TT;
real RH_avg = 0.0;
int i=0;
real MC_h2o;
real MW_h2o = mw[i_h2o];
real RH_av;
real T = C_T(c,t);
real Ru = 8.314;
real x = 6.0; /* doping level*/
real Ea = -619.6*x+21750;
real a = (168*x*x*x)-(6324*x*x)+(65750*x)+8460;
real b;
real sigma;
int zt = get_fc_zone_type(t->id);
/*d = Get_Domain(ROOT_DOMAIN_ID);*/
d = Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
volume = C_VOLUME(c,t);
TT = C_T(c,t);
P_sat = Get_P_sat(TT);
MC_h2o = C_YI(c,t,i_h2o);
/*C_h2o = C_YI(c,t,i_h2o)*C_R(c,t)/mw[i_h2o];*/
C_h2o = MC_h2o*C_R(c,t)/MW_h2o;
if (zt == aca_zone || zt == cca_zone)
vol_tot += volume;
RH_avg += (R_Gas*TT/P_sat*C_h2o)*volume;
end_c_loop(c,t)
RH_avg /= vol_tot;
RH_av = RH_avg;
b = 1+(0.01704*T-4.767)*RH_av;
sigma = a*b/T*exp(-Ea/Ru/T);
return sigma;
qwe2077 is offline   Reply With Quote
Old   March 9, 2015, 07:21
maverick123 is on a distinguished road
When you started calculation, what error was thrown exactly?
maverick123 is offline   Reply With Quote
Old   March 9, 2015, 07:31
Brian
error message was like this.
unable to read the cmd header on the pmi context, Error = -1
999999 (..\src\mpsystem.c@1173): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory
received suspend command for a pmi context that doesn't exist: unmatched id = 7
received suspend command for a pmi context that doesn't exist: unmatched id = 6
received suspend command for a pmi context that doesn't exist: unmatched id = 5
received suspend command for a pmi context that doesn't exist: unmatched id = 4
job aborted:
rank: node: exit code[: error message]
0: x70-jof7ksxthyb: -1073741819: process 0 exited without calling finalize
1: x70-jof7ksxthyb: -1073741819: process 1 exited without calling finalize
2: x70-jof7ksxthyb: -1073741819: process 2 exited without calling finalize
3: x70-jof7ksxthyb: -1073741819: process 3 exited without calling finalize
4: x70-jof7ksxthyb: -1073741819: process 4 exited without calling finalize
5: x70-jof7ksxthyb: -1073741819: process 5 exited without calling finalize
6: x70-jof7ksxthyb: -1073741819: process 6 exited without calling finalize
7: x70-jof7ksxthyb: -1073741819: process 7 exited without calling finalize
received suspend command for a pmi context that doesn't exist: unmatched id = 3
received suspend command for a pmi context that doesn't exist: unmatched id = 2
received suspend command for a pmi context that doesn't exist: unmatched id = 1
The Parallel FLUENT process could not be started.
Old   March 9, 2015, 07:45
I am not sure exactly about the cause. I doubt about partitioning.
You may use:
1.In FLUENT select the "Parallel" menu
2.Choose "Auto Partition"
3.Unselect "Case File"
4.Select "Metis" as the partition method
5.Choose OK
Old   March 9, 2015, 19:34
Brian
I've changed parallel menu as you said , but it still gives error message.
Even serial processing case throws error message.
When C_YI term was deleted, the case ran well....
Old   March 10, 2015, 02:33
Not sure, but the error seems related to parallel computing only.
http://stackoverflow.com/questions/1...ontext-error-1
Also try initializing C_YI terms with 0.0
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 15:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 10:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 00:31
