May 7, 2015, 01:13 |
How to give names to udf memory?
Rep Power: 10 |
In the contour plots C_UDMI(c,t,1) shows contours of user defined memory 1.
But I need this macro should display contours of velocity, temperature volume fraction etc.. How to give name to this macro? Any help would be appreciated |
May 7, 2015, 01:54 |
Rep Power: 18 |
Use the "Set_User_Memory_Name" function with the following format (read the section in the user's guide on User-Defined Memory for details).
void Set_User_Memory_Name(int i,char *name); |
May 7, 2015, 06:49 |
Rep Power: 10 |
Thank you.
Can you help me to solve this? Code:
#include "udf.h" #include "sg_udms.h" #include "math.h" #include "mem.h" #include "sg.h" " DEFINE_ADJUST(temp, d) { #if PARALLEL Domain *d; real tavg = 0.; real tmax = 0.; real tmin = 0.; real temp,volume,vol_tot; void Set_User_Memory_Name(int i,char *temp_ratio); Thread *t; cell_t c; d = Get_Domain(1); thread_loop_c(t,d) { begin_c_loop(c,t) { volume = C_VOLUME(c,t); temp = C_T(c,t); if (temp < tmin || tmin == 0.) tmin = temp; if (temp > tmax || tmax == 0.) tmax = temp; vol_tot += volume; tavg += temp*volume; } end_c_loop(c,t) tavg /= vol_tot; printf("\n Tmin = %g Tmax = %g Tavg = %g\n",tmin,tmax,tavg); begin_c_loop(c,t) { temp = C_T(c,t); C_UDMI(c,t,0) = (temp-tmin)/(tmax-tmin); C_UDMI(c,t,temp_ratio)= C_UDMI(c,t,0); } end_c_loop(c,t) } #endif } |
May 7, 2015, 07:55 |
Rep Power: 18 |
That's not how you call functions in C. The format I posted above was of the function declaration. Try the following code to call the function:
Set_User_Memory_Name(0, "temp_ratio"); Code:
C_UDMI(c,t,temp_ratio)= C_UDMI(c,t,0); |
May 8, 2015, 01:37 |
Rep Power: 10 |
I replaced but didn't work.. Can you modify?
#include "udf.h" #include "sg_udms.h" #include "math.h" #include "mem.h" #include "sg.h" " DEFINE_ADJUST(temp, d) { #if PARALLEL Domain *d; real tavg = 0.; real tmax = 0.; real tmin = 0.; real temp,volume,vol_tot; void Set_User_Memory_Name(int i,char *temp_ratio); Thread *t; cell_t c; d = Get_Domain(1); thread_loop_c(t,d) { begin_c_loop(c,t) { volume = C_VOLUME(c,t); temp = C_T(c,t); if (temp < tmin || tmin == 0.) tmin = temp; if (temp > tmax || tmax == 0.) tmax = temp; vol_tot += volume; tavg += temp*volume; } end_c_loop(c,t) tavg /= vol_tot; printf("\n Tmin = %g Tmax = %g Tavg = %g\n",tmin,tmax,tavg); begin_c_loop(c,t) { temp = C_T(c,t); C_UDMI(c,t,0) = (temp-tmin)/(tmax-tmin); Set_User_Memory_Name(0, "temp_ratio"); } end_c_loop(c,t) } #endif } |
May 8, 2015, 02:23 |
Rep Power: 18 |
You still have the following line in your code...
void Set_User_Memory_Name(int i,char *temp_ratio); |
May 8, 2015, 03:53 |
Rep Power: 10 |
May 8, 2015, 05:48 |
Rep Power: 26 |
Does the code do what you want it to do?
If so, it is ok. |
May 8, 2015, 06:01 |
#9 |
Rep Power: 10 |
Thank you
Yes. This is the only code.. Here I need to change inlet conditions, temperature values etc.. Code:
#include "udf.h" #include "sg_udms.h" #include "math.h" #include "mem.h" #include "sg.h" " DEFINE_ADJUST(temp, d) { #if PARALLEL Domain *d; real tavg = 0.; real tmax = 0.; real tmin = 0.; real temp,volume,vol_tot; Thread *t; cell_t c; d = Get_Domain(1); thread_loop_c(t,d) { begin_c_loop(c,t) { volume = C_VOLUME(c,t); temp = C_T(c,t); if (temp < tmin || tmin == 0.) tmin = temp; if (temp > tmax || tmax == 0.) tmax = temp; vol_tot += volume; tavg += temp*volume; } end_c_loop(c,t) tavg /= vol_tot; printf("\n Tmin = %g Tmax = %g Tavg = %g\n",tmin,tmax,tavg); begin_c_loop(c,t) { temp = C_T(c,t); C_UDMI(c,t,0) = (temp-tmin)/(tmax-tmin); Set_User_Memory_Name(0, "temp_ratio"); } end_c_loop(c,t) } #endif } |
May 8, 2015, 07:13 |
#10 | |
Rep Power: 26 |
Do you want to know if it compiles? Try it. Do you want to know if it does what you want it to do? I don't know, because I don't know what you want it to do. And what do you mean with "declare function as mentioned in the Manual"? Which part of the manual are you referring to? I only have one remark. One thing your code does, is set the name "temp_ratio" to UDM0 many times, where one time is enough. You don't have to put that in the loop, so you can make your code more efficient by putting that line somewhere else. |
May 10, 2015, 08:13 |
#11 |
Rep Power: 10 |
Thank you. I just needed the name of that udm-0 in the contour menu. I got it thank you very much.
May 10, 2015, 08:50 |
#12 |
Rep Power: 10 |
I have one more doubt. Can this udm be read in CFX post?
May 10, 2015, 17:46 |
#13 |
Rep Power: 18 |
UDM values can be visualised in CFD-Post. Ensure you have saved these values via File > Data File Quantities...
May 10, 2015, 23:59 |
#14 |
Rep Power: 10 |
May 11, 2015, 06:01 |
#15 |
Rep Power: 13 |
Have you read this udm in techplot? |
udf for 3d model to give heat flux profile around the wall surface | n7310889 | Fluent UDF and Scheme Programming | 3 | May 8, 2018 06:45 |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
Run-time memory allocation error | akalopsis | CFX | 0 | November 17, 2014 17:17 |
Lenovo C30 memory configuration and discussions with Lenovo | matthewe | Hardware | 3 | October 17, 2013 10:23 |
Identifying cell in parallel UDF | upeksa | Fluent UDF and Scheme Programming | 0 | July 24, 2013 11:27 |
