Why particle is not injected ?
2 Attachment(s)
Dear All,
Normally, I use DPM and set the injection from inlet surface. It works well. Then, I try to use DPM-DEM by 1) Activate Eulerian Multiphase flow, set Dense Discrete Phase 2) In Discrete Phase, I activate the DEM collision under Physical Tab 3) I choose collision partner (anthracite-anthracite) Problem 1) The particle is not injected ? I visualize by showing 1.1) particle variable > particle velocity 1.2) DPM concentration (Attachment 1) 2) Sometimes it show fatal error MPI Application rank 2 exit before finalize (Attachment 2) Anyone please kindly help, I am so desperate. |
