why UDS assigning does not work?
Old   January 26, 2016, 04:59
Default why UDS assigning does not work?
Przemek
gaza is on a distinguished road
Hi
I have such a piece of code:
# include "udf.h" # define domain_ID 1 DEFINE_ADJUST(adjust_gradient, domain) { Thread *t; cell_t c; face_t f; domain = Get_Domain(domain_ID); /* Fill UDS with the variable. */ thread_loop_c (t,domain) { begin_c_loop (c,t) {
// assign temperature values into User scalar 0
C_UDSI(c,t,0) = C_T(c,t); } end_c_loop (c,t) } }
I compiled and hooked this, allocated UDS (without flux) and did 50 iterations.
I checked contours of Static temperature and User scalar 0 and they
are not the same!!! Why it is so? I just assign temperature values
into User scalar 0 and it does not work. Please help.
best regards
pblasiak
gaza is offline   Reply With Quote
Old   January 26, 2016, 05:02
Przemek
# include "udf.h" # define domain_ID 2 DEFINE_ADJUST(adjust_gradient, domain) { Thread *t; cell_t c; face_t f; domain = Get_Domain(domain_ID); /* Fill UDS with the variable. */ thread_loop_c (t,domain) { begin_c_loop (c,t) { C_UDSI(c,t,0) = C_VOF(c,t); } end_c_loop (c,t) } }
best regards
pblasiak
Old   January 26, 2016, 05:11
pakk will become famous soon enough
No answer, but I reformat your code because it is very difficult to read in this way. You can do this yourself by adding
HTML Code:
[CODE][/CODE]
around your code.
Your last code, in a readable format, is this:
# include "udf.h"
   Thread *t;
   cell_t c;
   face_t f;
        end_c_loop (c,t)
pakk is offline   Reply With Quote
Old   January 26, 2016, 06:45
Przemek
Ok thank you.
I took the code from here (at the end)
http://jullio.pe.kr/fluent6.1/help/html/udf/node107.htm
it is from documentation and it does not work. Why???
best regards
pblasiak
Can you explain me how to use UDS? Tleja Fluent UDF and Scheme Programming 0 July 14, 2015 01:52
Set UDS on wall... fivos Fluent UDF and Scheme Programming 2 July 25, 2014 05:57
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 07:37
A good question about UDS Z FLUENT 1 March 31, 2005 15:14
UDS David FLUENT 1 March 21, 2005 11:31
