January 20, 2016, 09:31 |
Compile UDF for Fluent
Ganesh K C
Rep Power: 11 |
I need to include Lorentz force equation as a source term in my model. how can i compile a UDF and use it in fluent ?
-- K.C.Ganesh Research Scholar NIT Trichy India |
January 20, 2016, 16:03 |
Rep Power: 18 |
Use the DEFINE_SOURCE macro for specifying a custom source term (ensure the units are of the form generation rate per volume, e.g. kg/m^3/s for the continuity equation), there are a couple of examples in the UDF manual to get you started (ask back here if you get stuck). As for compiling UDFs, see the reply in your duplicate thread.
January 21, 2016, 11:42 |
Ganesh K C
Rep Power: 11 |
respected sir,
could suggest me what mistake i do in this code as given below ? #include "udf.h" #define mu 1.26*(10e-6) #define I 300 #define reff 0.008 #define r 0.005 /*-------------------------------------------------------- Momentum source term in x ----------------------------------------------------------*/ DEFINE_SOURCE(xmom_source,c,t,dS,eqn) { float x[ND_ND], source; face_t f; F_CENTROID (x,f,t); source =-((mu*I*I)/(4*3.14*3.14*reff*reff*r)) * (exp (-r*r / (2*reff*reff))) * (1-(exp (-r*r / (2*reff*reff)))) * pow((1-(x[1]/t),2) * (x[0]/r); dS[eqn] = 0; return source; } /*-------------------------------------------------------- Momentum source term in y ----------------------------------------------------------*/ DEFINE_SOURCE(ymom_source,c,t,dS,eqn) { float x[ND_ND], source; face_t f; F_CENTROID (x,f,t); source = -((mu*I*I)/(4*3.14*3.14*r*r)) * pow((1-(exp (-r*r / (2*reff*reff)))),2) * (1-(x[1]/t)); dS[eqn] = 0; return source; } /* HEAT INPUT CODE */ DEFINE_PROFILE(Gauss,t,i) { real x[ND_ND], c[ND_ND]; face_t f; real r; r = 0.0035; begin_f_loop(f, t) { F_CENTROID (x,f,t); F_PROFILE (f,t,i) = (3*(300*14*0.7) / (3.14*pow(r,2))) * exp (-3*(x[0]*x[0])/ pow(r,2)); } end_f_loop(f,t) }
January 21, 2016, 17:48 |
Rep Power: 18 |
For starters, use a trailing dot for real numbers (otherwise the compiler will read them as integers), for example:
F_PROFILE (f,t,i) = (3.*(300.*14.*0.7) / (3.14*pow(r,2))) * exp (-3.*(x[0]*x[0])/ pow(r,2)); |
January 29, 2016, 05:46 |
Ganesh K C
Rep Power: 11 |
i have modified the format with trailing dot as suggested. the UDF is given below and it gives the error: Line 27: invalid type for binary expression: float / pointer to structure.
how can i rectify the error in the following udf ? /*------ HEAT FLUX -------- */ #include "udf.h" DEFINE_PROFILE(Gauss,t,i) { real x[ND_ND], c[ND_ND]; face_t f; real r; r = 0.005; begin_f_loop(f, t) { F_CENTROID (x,f,t); F_PROFILE (f,t,i) = (3.*(300.*14.*0.7/0.001) / (3.14*pow(r,2.))) * exp (-3.*(x[0]*x[0])/ pow(r,2.)); } end_f_loop(f,t) } /*--------- Lorentz Force ----------*/ /*-------- x momentum source ------*/ #DEFINE mu 0.00000126; #DEFINE I 300.; #DEFINE reff 0.006; #DEFINE r 0.005; DEFINE_SOURCE(xmom,c,t,dS,eqn) { real x[ND_ND]; real mu, I, reff, r, source; C_CENTROID(x,c,t); source = -((mu*I*I)/(4.*3.14*3.14*reff*reff*r)) * (exp (-r*r / (2.*reff*reff))) * (1.-(exp (-r*r / (2.*reff*reff)))) * pow((1.-(x[1]/t),2.) * (x[0]/r)); dS[eqn]=0; return source; } /* ----------- y momentum source ------------*/ DEFINE_SOURCE(ymom,c,t,dS,eqn) { real x[ND_ND]; real source; C_CENTROID(x,c,t); source = -((mu*I*I)/(4.*3.14*3.14*r*r*c)) * pow((1.-(exp (-r*r / (2.*reff*reff)))),2.) * (1.-(x[1]/t)); dS[eqn]=0; return source; }
January 29, 2016, 08:29 |
Rep Power: 26 |
One of your problems is here:
#DEFINE mu 0.00000126; #DEFINE I 300.; #DEFINE reff 0.006; #DEFINE r 0.005; ... real mu, I, reff, r, source; Code:
real 0.00000126;, 300.;, 0.006;, 0.005;, source; Code:
#DEFINE I 300. Option 2: don't use #DEFINE: Code:
real mu=0.00000126, I=300, ... |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Compile udf error | Cfdbug | Fluent UDF and Scheme Programming | 2 | December 17, 2015 19:03 |
Compile c99 standard UDF in Cluster | darsonli | Fluent UDF and Scheme Programming | 0 | July 7, 2015 02:58 |
looking for instructions on how to compile an udf in windows OS | Srinivasa Rao | Fluent UDF and Scheme Programming | 2 | May 22, 2015 10:00 |
Fluent doesn´t compile UDF on Windows | HSeldon | FLUENT | 4 | February 14, 2007 23:01 |
