Fixed temperature for one phase in VOF
Hi guys, it's my first question in this forum. . I went back to work with Fluent recently.
I am working in a problem with two liquid phases and I want to set a fixed temperature in one of the phases, for the entire simulation. So, the temperature would be fixed in cell zones where there is entirely one phase. My question is, how do I do that? How can I set the temperature or a UDS fixed in the cell zone? The idea here is to use the Poisson equation for the energy as the similar electrostatic equation. In this way, the temperature would be the electric potential. Will this work? #include "udf.h" DEFINE_ON_DEMAND(on_demand_calc) { real frac; begin_c_loop(c,t) { frac = C_YI_G(c,t,1) if (frac > 0.9) C_T(c,T) = 1 } end_c_loop(c,t) } |
Regarding the piece of code you showed, frac is obtaining the value of the volume fraction gradient of species 1, not the volume fraction C_YI. There is also couple of lines where the " ; " is missing. In addition to that, the the DEFINE_ON_DEMAND, as the name says, is only define on demand, so you gotta execute it manually on Fluent. Not sure this is what you want. |
Yes... I see the code is wrong. But, I found out that I can do that thing with the macro DEFINE_ADJUST(name,d). I'll work on that. If pays off I'll post the code here.
