-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   UDF line 1 parse error (http://www.cfd-online.com/Forums/fluent-udf/32523-udf-line-1-parse-error.html)
Dimitrios November 15, 2003 08:39
Hi there fellow fluent users....this is the first time I've been using UDF's and I'm not a used user of Fluent. Anyway...I get an error message when trying to interpret the UDF in Fluent. The following message appears: line 1: parse error
My code is the following:
#include "udf.h" #include "dynamesh_tools.h"
DEFINE_CG_MOTION(rorlig_yttre, dt, cg_vel, cg_omega, time, dtime) { Thread *t = DT_THREAD ((Dynamic_Thread *)dt); face_t f; real force, dv, area, k_spring, s_force;
/* reset velocities */ NV_S (cg_vel, =, 0.0); NV_S (cg_omega, =, 0.0);
if (!Data_Valid_P ())
return;
/* compute force on rorlig_yttre wall */ force = 0.0; begin_f_loop (f, t)
force += F_P (f, t) * NV_MAG (F_AREA_CACHE (f, t)); end_f_loop (f, t)
#if RP_2D if (rp_axi)
force *= 2.0 * M_PI; #endif
/* compute change in velocity */ dv = dtime * force/ 1.2; v_prev += dv; loc += v_prev*dtime; Message ("time = %f, x_vel = %f, force = %f, loc(m)= %f \n", time, v_prev,
force,loc); Message ("time = %f, force = %f, spring = %f, loc(m)= %f \n", time, force,
s_force,loc);
cg_vel[0] = v_prev; }
Does anyone know why the error message pops up?
Ajay Rao November 15, 2003 13:28
Re: UDF line 1 parse error
Have your case file and UDF in c:\fluent.inc\ntbin\ntx86 folder ... It will run then ! -Ajay
Dimitrios November 16, 2003 06:21
You were right Ajay...it interpreted the file when .case and .c was in nt86 folder but now I get a new message: ***line 8: structure reference not implemented*** Can you perhaps see what can be wrong with my code?
Dimitrios November 16, 2003 06:43
By the way....line 8 is:
Ajay November 16, 2003 14:43
Hi, The error means that you cant use Interpreted UDF you have to use compiled UDF. compiled udf are bit more difficult to set up , you need to build the libraries and then load them. You should have an external compiler , VC++ compiler, thats the way i do it. Let me know if you need more help with it. -Ajay
ccc November 17, 2003 03:25
hi, Dimitrios:
Ajay is very right. there are some features of udf you can not use in the interpreted mode and Dynamic Mesh is one of them.
Dimitrios November 17, 2003 03:30
Dear Ajay
I would really appreciate if you could help me out with compiled UDF and the libraries setup.
Sincerely,
Dimitrios
Ajay Rao November 17, 2003 18:28
Hi, The New version of FLUENT has a GUI to help build and Load compiled UDF the older version have just the "Load" part. You would need Microsoft Visual Studio . Net for this ( I use it , dont know how to do with something else)
You need to follow the following steps
1) set up the environmental variable This is done by going to the start menu > Programs>Fluent> Set_environment clicking this would set the path and variable.
2) set up a directory structure as follows create a dir libudf in that create "src" and "ntx86". In ntx86 create "3d".( am asuming that ur simulation is 3d)
3) copy the udf (.C file) and the required header( u can get the header files frm c:\FLUENT.INC\fluent6.*.*\ntx86\src) files into the "src" folder.
4) go to c:\FLUENT.INC\fluent6.*.*\ntx86\3d copy the contents into the 3d folder which you created.
5) go to c:\FLUENT.INC\fluent6.*.*\ntx86\src copy makefile_nt.udf and user_nt.udf to your 3d folder
6) rename makefile_nt.edf to makefile and open user_nt.udf and read the instructions and do accordingly.
7) close FLUENT . Open command prompt ( start > accessories > command prompt ) type the following C:\ CD program Files \ microsoft visual studio .net\vc7\bin
8) type :- vcvars32
9)go to the libudf\ntx86\3d which u have created
10) type nmake
11) This will compile ur code and build a lib if u dont have any errors , if errors are present it will say so u need to debug it then.
12) once this is done u can open fluent again and load the lib u have just created , in this case it would be libudf.
I know its confusing ! Keep trying it took me a long time to get all things correct.
All the best Ajay
Dimitrios November 18, 2003 03:17
Once again Ajay....thanks for the help....now the code is working great....a small problem though...I have two reals that I want them to both have the value zero in the first iteration. If I define them as vel=0 and time=0 in the beginning of the code, where I define all my reals, they tend to get zero after each new iteration. How can I write the code so they have the value zero only in the first iteration?
Ajay Rao November 18, 2003 10:22
Hi Dimitrios , You could compare the time ,
real time;
time=RP_Get_Real("flow-time")
if (time ==0) { initialize
Hope this helps , -Ajay
17_freedom April 6, 2011 01:32
Thank you,I also meet the same problem.Thank you!
theja January 23, 2012 05:13
parse error line62
Originally Posted by Dimitrios
;109119
Dear Ajay
Sincerely,
Dimitrios
can you please help me out of this, i am getting parse error at line 62 when i am interpreting this udf valve.c
# include "udf.h"
# include "dynamesh_tools.h"
# ifndef intloop
# define intloop(n,m)for(n=0;n<m;++n);
# endif
/********************** Input Explanation Starts ***************************
DEBUG: will print out debug information.
NO_OF_VALVES: Number of valves
NO_OF_ZONES: a large number which is larger than the max number of face
zones per valve
valveid[NO_OF_VALVES][NO_OF_ZONES]={{22, 23, -1}, {13, 14, -1}}: valve face
zone list, in this example, invalve consists of face zone 21 and 23,
exvalve consists of face zone 13 and 14. -1 is a flag and so keep it.
These face zones will be used to calculate the pressure force.
axis[NO_OF_VALVES][ND_ND]={{0, 0, 1}, {0, 0, -1}}: valve motion axis. It points
from the max lift to min lift. And it has to be normalized.
r_rp_closed[NO_OF_VALVES][ND_ND]={{-0.025, 0, 0}, {0.025, 0, 0.005}}: The
reference point coordinates when valves are closed. A reference point,
used to keep track of valve motion, is a point in the valve. The
loation in the valve is immaterial and you can conveniently choose
the location.
lift_min[NO_OF_VALVES]={0.0005, 0.0005}: minimum lift
lift_max[NO_OF_VALVES]={0.01, 0.006}: maximum lift
rest_conts[NO_OF_VALVES]={0.5, 0.5}: bouncing factor
mass[NO_OF_VALVES]={0.02, 0.02}: valve mass
stiffness[NO_OF_VALVES]={2000, 5000}: valve stiffness
stretch_at_closed[NO_OF_VALVES]={0.002, 0.004}: what is the valve stretching
length when the valves are closed
gravity_direction: Gravitational direction. Has to be normalized.
current_vel_mag[NO_OF_VALVES]: Initial velocity. Could be negative if opposite
to valve axis
cur_r_rp[NO_OF_VALVES][ND_ND]: Initial position
previous_time[NO_OF_VALVES]: Initial time. Normally just 0.
How to use the udf:
- Modify the user input part of the udf. If more than one valve,then one needs to add
more DEFINE_CG_MOTION. See below for more details.
- Build the lib and hook the reader writer udf
- Use the udf for the valve motion
Note that this UDF is only valid in single precision.
Written by : Xiao Hu (Fluent Inc)
Last updated : 11/30/2004
********************** Input Explanation Ends *****************************/
/*************************** User Input Starts *****************************/
# define DEBUG
# define NO_OF_VALVES 1
# define NO_OF_ZONES 3
static int valveid[NO_OF_VALVES][NO_OF_ZONES]={{10, -1}};
static real axis[NO_OF_VALVES][ND_ND]={{-1,0}}; /* normalized */
static real r_rp_closed[NO_OF_VALVES][ND_ND]={{-0.01016, 0}};
static real lift_min[NO_OF_VALVES]={0};
static real lift_max[NO_OF_VALVES]={1e5};
static real rest_conts[NO_OF_VALVES]={0};
static real mass[NO_OF_VALVES]={0.01};
static real stiffness[NO_OF_VALVES]={150000};
static real stretch_at_closed[NO_OF_VALVES]={0};
static real gravity_direction[ND_ND]={0, 1}; /* normalized */
static real current_vel_mag[NO_OF_VALVES]={0};
static real cur_r_rp[NO_OF_VALVES][ND_ND]={{0, 0}};
static real previous_time[NO_OF_VALVES]={0};
/*************************** User Input Ends *******************************/
static void f_valve(int valveNo, void *dt, real *cg_vel, real *cg_omega, real time, real dtime)
#if !RP_HOST
real tmp[ND_ND], dv, current_vel[ND_ND], CG[ND_ND], force[3], moment[3], stretch;
real aero_force[ND_ND], aero_force_axis, spring_force, net_force, r_rp_new[NO_OF_VALVES][ND_ND];
int i;
Thread * tf;
Domain * domain;
static real cg_vel_saved[NO_OF_VALVES][ND_ND];
/* Do the calculation if the new time step */
if(fabs(previous_time[valveNo]-time)>0.2*dtime)
/* Check to see if there is data */
Message0("\n\nNo data->No mesh motion!!!\n\n");
return;
/*Calculate force*/
domain = THREAD_DOMAIN (DT_THREAD ((Dynamic_Thread *)dt));
i=0;
NV_S(aero_force,=,0);
while(valveid[valveNo][i]>=0)
tf=Lookup_Thread(domain, valveid[valveNo][i]);
NV_S (CG, =, 0.0);
Compute_Force_And_Moment (domain, tf, CG, force, moment, FALSE);
NV_V(aero_force,+=,force);
i++;
aero_force_axis=NV_DOT(aero_force, axis[valveNo]);
NV_VV(tmp,=,r_rp_closed[valveNo],-,cur_r_rp[valveNo]);
stretch = (stretch_at_closed[valveNo]+NV_DOT(tmp,axis[valveNo]));
spring_force=stiffness[valveNo]*stretch;
net_force=spring_force+aero_force_axis+9.81*mass[valveNo]*NV_DOT(gravity_direction, axis[valveNo]);
dv=net_force/mass[valveNo]*dtime;
/* Calculate the C.G location and velocity if it does not hit the boundary */
NV_VS(current_vel,=,axis[valveNo],*,current_vel_mag[valveNo]);
NV_VS(tmp,=,current_vel,*,dtime);
NV_VV(r_rp_new[valveNo],=,cur_r_rp[valveNo],+,tmp);
/* Update velocity */
current_vel_mag[valveNo]+=dv;
/* debug info */
#ifdef DEBUG
Message0("\n\n*********************** DEBUG INFO ***************************\n");
Message0("\nvalveNo=%3d\n", valveNo);
Message0("\ncur_r_rp[%d]=(%10.3e, %10.3e, %10.3e)\n",
valveNo, cur_r_rp[valveNo][0], cur_r_rp[valveNo][1], cur_r_rp[valveNo][ND_ND-1]);
Message0("\naero force=(%10.3e, %10.3e, %10.3e)\n",
aero_force[0], aero_force[1], aero_force[ND_ND-1]);
Message0("\n(stretching at closed, stretching, force)=(%10.3e, %10.3e, %10.3e)\n",
stretch_at_closed[valveNo], stretch, spring_force);
Message0("\n(net_force, spring force, aero force)=(%10.3e, %10.3e, %10.3e)\n",
net_force, spring_force, aero_force_axis);
Message0("\nvel(cur)=%11.3e vel(next wo limit)=%11.3e ",
current_vel_mag[valveNo]-dv, current_vel_mag[valveNo]);
#endif
/* if it hits the lift_min boundary then it stays at lift_min*/
NV_VV(tmp,=,r_rp_closed[valveNo],-,r_rp_new[valveNo]);
if(NV_DOT(tmp,axis[valveNo])<(lift_min[valveNo]))
NV_V_VS(r_rp_new[valveNo],=,r_rp_closed[valveNo],-,axis[valveNo],*,lift_min[valveNo]);
current_vel_mag[valveNo]=-rest_conts[valveNo]*fabs(current_vel_mag[valveNo]);
/* if it hits the lift_max boundary then it stays at lift_max*/
if(NV_DOT(tmp,axis[valveNo])>(lift_max[valveNo]))
NV_V_VS(r_rp_new[valveNo],=,r_rp_closed[valveNo],-,axis[valveNo],*,lift_max[valveNo]);
current_vel_mag[valveNo]=rest_conts[valveNo]*fabs(current_vel_mag[valveNo]);
/* set valve velocity */
NV_VV(tmp,=,r_rp_new[valveNo],-,cur_r_rp[valveNo]);
NV_VS(cg_vel,=,tmp,/,dtime);
/* Update location and velocity */
NV_V(cur_r_rp[valveNo],=,r_rp_new[valveNo]);
NV_V(cg_vel_saved[valveNo],=,cg_vel);
previous_time[valveNo]=time;
/* debug info */
#ifdef DEBUG
Message0("vel(next w limit)=%11.3e\n", current_vel_mag[valveNo]);
Message0("\nvelocity(CG)=(%10.3e, %10.3e, %10.3e)\n",
cg_vel[0], cg_vel[1], cg_vel[ND_ND-1]);
Message0("\nr_rp_new[%d]=(%10.3e, %10.3e, %10.3e)\n",
valveNo, r_rp_new[valveNo][0], r_rp_new[valveNo][1], r_rp_new[valveNo][ND_ND-1]);
Message0("\n*********************** DEBUG INFO ***************************\n\n");
#endif
else
NV_V(cg_vel,=,cg_vel_saved[valveNo]);
#endif
node_to_host_real(current_vel_mag, NO_OF_VALVES);
node_to_host_real(cur_r_rp[0], NO_OF_VALVES*ND_ND);
node_to_host_real(previous_time, NO_OF_VALVES);
/* Add more valves if necessary. For instance, if two valves, then
f_valve(0, dt, cg_vel, cg_omega, time, dtime);
f_valve(1, dt, cg_vel, cg_omega, time, dtime);
DEFINE_CG_MOTION(valve, dt, cg_vel, cg_omega, time, dtime)
node_to_host_real(cg_vel,ND_ND);
node_to_host_real(cg_omega,ND_ND);
DEFINE_EXECUTE_AT_END(output_results)
#if !RP_HOST
int i;
FILE *fp_results;
#if PARALLEL
if(I_AM_NODE_ZERO_P)
#endif
if(!(fp_results=fopen("results.txt","a")))
Message0("\nCan not open file-aborting!!");
exit(0);
#if PARALLEL
#endif
fprintf(fp_results, "%12.4e ", CURRENT_TIME);
for(i=0; i<NO_OF_VALVES; i++)
fprintf(fp_results, "%12.4e ", NV_DOT(cur_r_rp[i],axis[i]));
fprintf(fp_results, "\n");
fclose(fp_results);
#endif
static void write_data(FILE *fp)
int i, j;
fprintf(fp, "%e ", current_vel_mag[i]);
fprintf(fp, "\n");
for(j=0; j<ND_ND; j++)
fprintf(fp, "%e ", cur_r_rp[i][j]);
fprintf(fp, "\n");
fprintf(fp, "\n");
fprintf(fp, "%e ", previous_time[i]);
DEFINE_RW_FILE(writer, fp)
Message0("Writing UDF data to data file...\n");
#if PARALLEL
#if RP_HOST
write_data(fp);
#endif
#else
write_data(fp);
#endif
static void read_data(FILE * fp)
int i, j;
fscanf(fp, "%e", current_vel_mag+i);
fscanf(fp, "%e", cur_r_rp[i]+j);
fscanf(fp, "%e", previous_time+i);
DEFINE_RW_FILE(reader, fp)
Message0("Reading UDF data from data file...\n");
#if PARALLEL
#if RP_HOST
read_data(fp);
#endif
#else
read_data(fp);
#endif
host_to_node_real(current_vel_mag, NO_OF_VALVES);
host_to_node_real(cur_r_rp[0], NO_OF_VALVES*ND_ND);
host_to_node_real(previous_time, NO_OF_VALVES);
thanks in advance
n7310889 August 9, 2012 19:44
Originally Posted by Ajay Rao
;109092
Hi Ajoy, As a test case I have just copied a udf of inlet_x_velocity and modified it slightly to check with a fluent model. But strangely enough, it also shows the similar error message that of Dimitrios one. Obviously, I have followed your instruction and tried several times with different modifications. But the problem is persistent with a little change from line 1 to line 2 then finally line 3. Could you please check the code whats going wrong?
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND];
real y, h;
face_t f;
h = 33.;
begin_f_loop(f,thread)
F_CENTROID(x, f, thread);
y = (2.*x[1]- h)/h;
F_PROFILE(f, thread, position) = 2.5*(1.0-y*y);
end_f_loop(f, thread)
endalke September 28, 2012 02:54
fluent codding error
dear fluent users, i am a new user of fluent. trying to solve a 2D cross flow turbine. i use a UDF for the 2D model. my code is
/*This code is written in "C"*/
/*UDF starts for the rotor*/
#inc1ude "udf.h"
#inc1ude "dynamesh_tools.h"
/*UDF starts for Rotational Speed of rotor*/
DEFINE_CG_MOTION(rotor,dt,vel,omega,time,dtime)
NY_S(vel,=,0.0);
NY_S(omega,=,0.0);
/*Linear Velocity for blade and pipe*/
vel[O]=0.0;
vel[l]=0.0;
vel[2]=0.0;
/*Angular Velocity for blade and pipe*/
omega[O]=0;
omega[l]=0;
omega[2]=12;
/*Messages for Display*/
Message("\nThis is the rotor\n");
Message("\nCG_Omega for rotor: %g, %g, %g\n",omega[O],omega[1],omega[2]);
Message("\nCG_Position for rotor: %g, %g, %g\n",NV_LIST(DT_CG(dt)));
Message("\nCG_Orientation for rotor: %g, %g, %g\n",NY_LIST(DT_THETA(dt)));
/*UDF ends for Rotational Speed of blade and pipe*/
but when i try to compile the UDF i found an error message follow below
1 file(s) copied.
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\2ddp\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "ntx86\2ddp")()
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Done.
"D:/model"
Opening library "libudf"...
Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
is any one knows what it mean? and how to solve it, please help me.
mactech001 October 8, 2012 04:46
UDF parse error with DEFINE_PROFILE
;109092
Dear Ajay,
Thx to your comments here.
I met a similar problem while using DEFINE_PROFILE (My code attached below. it is actuall an example from Help). The error points to line #1, which is the comment line.
/* Wall Heat Generation Rate Profile UDF */
#include "udf.h"
DEFINE_PROFILE(wallheatgenerate,thread,i)
real source = 0.001;
face_t f;
F_PROFILE(f,thread,i) = source;
end_f_loop(f,thread)
i copied the Case file and the C-code shown above into the folder directory: C:\Program Files\ANSYS Inc\v130\fluent\ntbin\ntx86
But the same error occurs while interpreting.
What else could be incorrect please?
Hope to obtain your guidance/comments as soon as possible. Thx!
Regards,
Mactech001
Using: ANSYS WB v13
nkme2007 October 10, 2012 06:22
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT.
Can anybody help me out, how to model and simulate?
Does any tutorials exist?
Payam89 October 31, 2012 12:50
#include "udf.h"
#define Q 1.0;
#define e 1.0;
#define er 3.0;
#define pi 3.1;
#define s 0.0187;
DEFINE_SOURCE(xmom_source,c,t,ds,eqn)
real source;
real x[ND_ND];
ds[eqn]=-(Q/2.*pi*e)*(1./x + 1./s-x);
return source;
Error: C:\Users\USER\Desktop\ss.c: line 13: parse error.
Error: C:\Users\USER\Desktop\ss.c: line 13: invalid type for pointer dereference: float.
thanks
vmtlv November 30, 2012 23:18
#if !RP_HOST
int i;
Thread * tf;
Domain * domain;
return;
/*Calculate force*/
i=0;
NV_S (CG, =, 0.0);
i++;
/* debug info */
#ifdef DEBUG
#endif
/* debug info */
#ifdef DEBUG
#endif
else
#endif
Hi, I can't understand "valveNo" that was most used in "f_valve" , how value does it has ?
Thanks for reading !
ghost82 December 2, 2012 12:35
Originally Posted by Payam89 (Post 389511)
#include "udf.h"
#define Q 1.0;
#define e 1.0;
#define er 3.0;
#define pi 3.1;
#define s 0.0187;
real source;
real x[ND_ND];
return source;
thanks
you need to specify x[0], which is the x coordinate, or x[1], which is the y coordinate, or x[2], the z coordinate.
mactech001 January 11, 2013 01:52
UDF code understanding
dear all,
does the code below applies a constant heat flux of 0.001W/m^2 to the wall please?
/* Wall Heat Generation Rate Profile UDF */#include "udf.h" DEFINE_PROFILE(wallheatgenerate,thread,i) { real source = 0.001; face_t f; begin_f_loop(f,thread) F_PROFILE(f,thread,i) = source; end_f_loop(f,thread) } Regards,mactech001
