-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   fluent UDF on linux machine (http://www.cfd-online.com/Forums/fluent-udf/33869-fluent-udf-linux-machine.html)
Min-Hua Wang June 2, 2004 14:34
Hi, All:
I am running fluent 5/6 on a linux machine. Does any one experience using UDF in fluent simulation on that machine.
Which makefile should I get from fluent directory. How to compile it and link to solver. I don't have a problem in running fluent on a Unix machine.
Thanks
MHW
D Harvey June 4, 2004 13:19
Re: fluent UDF on linux machine
you will get two makefiles. your directory structure should look like this in linux
/home/username
so place the UDF directory as follows:
/home/username/UDF
then libudf
/home/username/libudf
then add lnx86
/home/username/libudf/lnx86
then add src
/home/username/libudf/src
then in the lnx86 dir
add 2d 3d 3ddp (this corresponds to 2d 3d and 3d double precision)
then in the source directory you place your .c code
cp /directory location of fluent/Fluent.Inc/fluent6.1.??/src/makefile.udf /home/username/UDF/libudf/src/makefile cp /directory location of fluent/Fluent.Inc/fluent6.1.??/src/makefile.udf2 cp /home/username/UDF/libudf/Makefile
that should do it.
Cheers,
DH
D Harvey June 4, 2004 13:20
/home/username
/home/username/UDF
then libudf
then add lnx86
then add src
that should do it.
Cheers,
DH
D Harvey June 4, 2004 13:21
ignore the first reply it had an error.
BTW this is all in the UDF manual, which you will need.
Podila June 11, 2004 17:18
Please contact smadhava@dal.ca. I guess he is the right person to help u with. Bye Podila
zhangyluck January 15, 2013 04:57
[QUOTE=D Harvey
;113010]
there should be no 'cp' in the second sentence
majid_m87 June 29, 2013 08:41
UDF syntax error
Hi all,
I did write a UDF for inlet velocity of my fluent case, but every time I try to interpreted it in Fluent, it says
"Error: /home/mp-current/9-2nd-50-tran/inlet_velocity.c: line 2: syntax error."
I will appreciate it if anyone help me in this case.
and this my UDF Vleocity profile
#include"udf.h"
DEFINE_PROFILE(inlet_velocity, thread, position) /* inlet x velocity = name of the x velocity */
real x[ND_ND]; /* this will hold the position vector */
real z;
face_t f; /* f = all the cell faces on the boundary*/
begin_f_loop(f,thread) /* thread = given boundary zone, defined automatically when the UDF is hooked to inlet boundary, the macro begin_f_loop is applied to all the cell faces*/
F_CENTROID(x, f, thread); /* the coordinates of the face centroid accessed by F_CENTROID */
z= x[1];
F_PROFILE(f, thread, position) = pow((60+z)/60,(1/7))+((50+z)/5); /* return velocity is assigned through F_PROFILE */
end_f_loop(f, thread)
