UDF Radiation model for combustion
Old   July 27, 2009, 14:25
Question UDF Radiation model for combustion
siva kumar
shshiva17 is on a distinguished road
Hi,,,This is siva kumar from IIT MADRAS....while am interpret my udf the error is showing like.....
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
this error is coming in my fluent model when i interpret the source code as shown in below....fuel is methane
#include "udf.h"
DEFINE_SOURCE(energy,c,t,ds,eqn)
/*FILE *fp;*/
real source,tep,sigma,Pamb,tamb;
real MW[18];
real Xh2o,Xco,Xco2,Xch4,ph2o,pco,pco2,pch4;
real MWmix,sum=0;
real kapa,absh2o,absco,absco2,absch4;
real a0,a1,a2,a3,a4,a5;
real b0,b1,b2,b3,b4,b5;
real c0,c1,c2,c3,c4;
real d0,d1,d2,d3,d4;
int i;
/*fp=fopen("properties.txt","w");*/
tep=C_T(c,t);
MW[0]=1;
MW[1]=32;
MW[2]=17;
MW[3]=16;
MW[4]=2;
MW[5]=18;
MW[6]=33;
MW[7]=28;
MW[8]=44;
MW[9]=16;
MW[10]=15;
MW[11]=14;
MW[12]=30;
MW[13]=29;
MW[14]=31;
MW[15]=34;
MW[16]=13;
MW[17]=28;
sigma=0.000000056697;
Pamb=1.0;
tamb=298.0;
a0=18.741;
a1=-121.310;
a2=273.500;
a3=-194.05;
a4=56.31;
a5=-5.8169;
b0=-0.23093;
b1=1.12393;
b2=9.4153;
b3=-2.99880;
b4=0.51382;
b5=-.000018684;
c0=6.6334;
c1=-0.0035686;
c2=0.000000016682;
c3=0.00000000025611;
c4=-0.000000000000026558;
if(tep<=750)
d0=4.7869;
d1=-0.06953;
d2=0.000295775;
d3=-0.000000425732;
d4=0.000000000202894;
else
if(tep>750)
d0=10.09;
d1=-0.01183;
d2=0.0000047753;
d3=-0.000000000587209;
d4=-0.000000000000025334;
for(i=0;i<18;i++)
sum=sum+C_YI(c,t,i)/MW[i];
MWmix=1/sum;
Xh2o=C_YI(c,t,5)*MWmix/18;
Xco=C_YI(c,t,7)*MWmix/28;
Xco2=C_YI(c,t,8)*MWmix/44;
Xch4=C_YI(c,t,9)*MWmix/16;
ph2o=Xh2o*Pamb;
pco=Xco*Pamb;
pco2=Xco2*Pamb;
pch4=Xch4*Pamb;
absch4=c0+(c1*tep)+(c2*pow(tep,2))+(c3*pow(tep,3)) +(c4*pow(tep,4)
absco2=a0+(a1*(1000/tep))+(a2*pow(1000/tep,2))+(a3*pow(1000/tep,3
))+(a4*pow(1000/tep,4))+(a5*pow(1000/tep,5));
absco=d0+(d1*tep)+(d2*pow(tep,2))+(d3*pow(tep,3))+ (d4*pow(tep,4))
absh2o=b0+(b1*(1000/tep))+(b2*pow(1000/tep,2))+(b3*pow(1000/tep,3
))+(b4*pow(1000/tep,4))+(b5*pow(1000/tep,5));
kapa=(absch4*pch4)+(absco*pco)+(absco2*pco2)+(absh 2o*ph2o);
source=-(4*sigma*kapa*(pow(tep,4)-pow(tamb,4)));
/*fprintf(fp,"%f%f%f\n",tep,source,MWmix);*/
ds[eqn]=0;
return source;
why the error is coming i don't know please help me??????
shshiva17 is offline   Reply With Quote
Old   July 29, 2009, 10:44
Micael
Micael is on a distinguished road
Hello Siva,
Notice the space into your variable:
Delete that space and it should be ok:
kapa=(absch4*pch4)+(absco*pco)+(absco2*pco2)+(absh2o*ph2o);
Have a good day.
Micaël
Micael is offline   Reply With Quote
Old   July 29, 2009, 10:59
Smile Thank u very much Micaël
siva kumar
i willl try that.....thank u very much for ur reply...keep in touch with me,,,,,
Old   July 29, 2009, 12:28
Thumbs down hey Micaël
siva kumar
i have tried but it is not working man,,,,,???
Old   July 29, 2009, 18:34
Micael
Sorry, I had not tried the UDF, only saw this space and reported it. Now I can see too that there is another problem, more difficult to find.
That is not clear to me, but the problem seems to come from C_YI(c,t,i). Using only a Species Transport model, I can successfully use your UDF. Which model do you use?
Someone reported problem using C_YI(c,t,i) with a pdf combustion model:
http://university.fluent.com/forum/v...814ae1a27f690d
Hope this can helps.
Micaël
Old   July 30, 2009, 01:59
Smile Micaël
siva kumar
hi,,,,miceal,,,am using species transport model .......how can it be solved...?
see miceal am not using pdf combustion model am using only species transport model......???
Old   July 30, 2009, 10:19
Micael
Here is what I did:
I enabled Species Transport. I choose "mixture-template" in the Mixture Material drop-down list. In the Materials panel, I added arbitrary fluid materials in that mixture up to 18. Finally, I hooked the UDF in the boundaries panel, adding energy source in the fluid zone. I did few iterations without bug. Do you use it that way?
If you have less then 18 species defined in your mixture there is a bug here in your code:
for(i=0;i<18;i++)
You can easily see how many species you have:
Define -> Models -> Species -> Transport & Reaction
Just look at the right of "Number of Volumetric Species"
Old   July 30, 2009, 10:49
Thumbs down
siva kumar
u have run that file...
did get running the fluent with out error....but mine is error is coming again,,,???
Old   July 30, 2009, 11:33
Micael
You have defined 18 species in your mixture?
If yes, then I don't know what is the problem.
Old   July 30, 2009, 12:03
Smile miceal..
siva kumar
hi miceal my problem is 2 step methane combustion....total products are 6 how can i give 18 products ,,,,
i think we need to change the udf into 6 species,,,,,,isn't it???
Old   July 30, 2009, 12:58
Micael
Did your write this UDF yourself? What it does? What is "MW"?
I thought you have 18 species because of this:
for(i=0;i<18;i++)
i in C_YI(c,t,i) is species index (integer)
What this loop intend to do?
Since you have 6 species, now it is clear to me that the problem is there.
Don't give up.
Old   July 16, 2017, 13:11
Default absorption
  #12
sewgolam is on a distinguished road
Dear friends,
as I saw the UDF you are calculating absorption for each species that are present in the domain and give it as a source value. how is this source define in fluent
because the heat is only absorped in the cell where these species are present en not else were.
I want to used DPM to inject particle and that calculate the absorpted heat by radiation. how could I used this UDF
please help
sewgolam is offline   Reply With Quote
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
can alternate combustion model by UDF? Han Xingsi FLUENT 0 September 1, 2008 02:08
Radiation Model - Spectral Model Ray CFX 3 April 10, 2006 09:33
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 03:07
RE: Radiation model Ashutosh Joshi FLUENT 1 January 30, 2001 10:50
