UDF saving data to a text file
Old   May 1, 2013, 06:29
Default UDF saving data to a text file
fleure_Jasmin is on a distinguished road
Hello everyone,
I'm working on a case of particle injected into a flow and subjected to ultrasound radiation force. I then modeled this force as body force and I introduced it in fluent using Udf where the variable returned is named radforce. The problem is that I can’t see this force in fluent console even if I add this line: Message (‘’ force: %g\n ‘’,radforce) ;
I also tried to write force calculated data in a text file, but nothing works the text file which is in the same folder as the case and the data is empty.
BODY_FORCE(…)
{ FILE *fp;
real radforce;
…/*calcule of radiation force*/
if(NULL == (pf = fopen("data.txt","w")))
Error("Could not open file for append!\n");
fprintf(pf,"%e\n",radforce);
fclose(pf);
If someone has an idea and can help I will be really grateful.
Thank you very much J
fleure_Jasmin is offline   Reply With Quote
Old   May 1, 2013, 07:53
blackmask will become famous soon enough
Why fp appeared in the declaration section
FILE *fp;
but pf is used in the following
pf = ...
fprintf(pf...) ?
No error during compilation?
blackmask is offline   Reply With Quote
Old   May 1, 2013, 09:06
Oh thank you Blackmask but it was just a typo when writing this message but the file is fp
Old   May 1, 2013, 09:10
actually the problem is in the compilation
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
UDF (write a data file) problem lichun Dong FLUENT 2 July 29, 2005 11:39
