Get gradient from uds
Old   October 24, 2010, 05:59
Default Get gradient from uds
qwerty753
qwerty753 is on a distinguished road
I defined an uds.
As postprocessing fluent allows to read the uds variable by contour etc.
I just want to reat the gradient of my variable for a surface integral or a plot.
How can i get it?
Thank you
qwerty753 is offline   Reply With Quote
Old   October 25, 2010, 01:50
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Check the UDF Manual at 3.2.3 Cell Macros (to see when and how you make available the gradients to your udf), and after that try the macro C_UDSI_G.
dmoroian is offline   Reply With Quote
Old   October 25, 2010, 06:31
qwerty753
Thank you for your help!
I wrote this udf:
# include "udf.h"
# define domain_ID 2
DEFINE_ON_DEMAND(store_gradient)
Domain *domain;
cell_t c;
Thread *t;
domain=Get_Domain(1);
/* Fill the UDM with magnitude of gradient. */
thread_loop_c (t,domain)
begin_c_loop (c,t)
C_UDMI(c,t,0) = C_UDSI_G(c,t,0)[1];
end_c_loop (c,t)
This doesn't work becouse if i execute on demand i receive this message:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
Domain *domain;
cell_t c;
Thread *t;
begin_c_loop (c,t)
C_UDMI(c,t,0) = C_UDSI(c,t,0);
end_c_loop (c,t)
to check if it run...i have no problem, why?
Old   October 25, 2010, 07:25
dmoroian's Avatar
Dragos
As I said previously :
I'll give you a hint: the memory for the gradient is not allocated when you try to access C_UDSI_G, so look for the gradient paragraph in the above section of the manual!
Old   October 25, 2010, 07:33
qwerty753
OK i understood my error...
solve/set/expert and then answering yes to the question Keep temporary solver memory from being freed?
i set correctly and now it runs.
But i discover that the gradient is calcolated by uds at cell... i need at face because i'm at B.C..
Is there any procedure?
Old   October 25, 2010, 11:38
dmoroian's Avatar
Dragos
If you use second order discretisation scheme, then the gradient is constant over the entire cell, so you may use the cell value on the boundary face.
Otherwise, just as wild guess try F_UDSI_G.
Old   July 27, 2012, 13:52
mila_oliv is on a distinguished road
hey qwerty753,
did you solve your problem?
I need the gradient too, but it's inserted in my function, so i dont need to postprocess the gradient directly...
look what i've done:
#include "udf.h"
DEFINE_ON_DEMAND(heat_flux_lines)
Domain *d;
Thread *t;
cell_t c;
real H;
real rho,u,Temp,k,dTdx;
d=Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
rho=C_R(c,t);
u=C_U(c,t);
Temp=C_T(c,t);
k=C_K_L(c,t);
dTdx=C_T_G(c,t)[0];
H+=((rho*u*Temp)-(k*dTdx))*0.1;
C_UDMI(c,t,1)=H;
end_c_loop(c,t)
mila_oliv is offline   Reply With Quote
Gradient of UDS gemini Fluent UDF and Scheme Programming 2 December 24, 2013 00:24
How to compute UDS fourth order gradient Emma66 FLUENT 1 April 27, 2010 05:44
reconstruction gradient of a UDS gemini Fluent UDF and Scheme Programming 0 June 7, 2009 16:03
Gradient UDS tom FLUENT 1 April 28, 2006 03:46
Gradient of a UDS Ilkay FLUENT 0 March 8, 2000 13:42
