Home > Forums > Fluent UDF and Scheme Programming
problem with Define_on_demand
Old   April 15, 2009, 08:44
Default problem with Define_on_demand
R. Roy
rr123 is on a distinguished road
dear all,
this is my code:
#include"udf.h"
#include"dpm.h"
#include"surf.h"
int num_injection = 4;
DEFINE_ON_DEMAND(initalize_udmis)
Domain *d=Get_Domain(1);
Thread *tc;
cell_t c;
int injno = 0;
/* Init UDM */
if(injno < num_injection)
thread_loop_c(tc,d){
begin_c_loop(c,tc)
C_UDMI(c,tc,injno)=0;
end_c_loop(c,tc)
injno++;
when i use this code for initializing the User defined memories (i already put the UDM limit to 10); i get segmentation violation.
why is this so ?
can you help me to avoid this problem.
sincerely.
rr123 is offline   Reply With Quote
Old   April 16, 2009, 05:35
O.D.Y.'s Avatar
O.D.Y. is on a distinguished road
unfortunately I can not help you with your problem, but I'm experiencing exactly the same problem. I'm using DEFINE_ON_DEMAND and the UDM brings up a segmentation violation. I'm using FLUENT under Linux AMD 64, what are you using?
regards
O.D.Y. is offline   Reply With Quote
Old   April 16, 2009, 05:48
O.D.Y.'s Avatar
Hi again,
I found the solution in this thread: C_UDMI - SEGMENTATION VIOLATION
I don't know why it works this way, but it works.... So You have to display the UDM in the contours before executing the UDF!
cheers
Old   April 16, 2009, 07:58
R. Roy
dear sir,
thank you for this very important message and for letting me know the work-around.
sincerely.
Old   April 17, 2009, 08:03
R. Roy
i still have problems with the UDF.
the initialization works.
however, the simulation crashes with:
Error: > (greater-than): invalid argument [2]: wrong type [not a number]
Error Object: nan
the UDF is related to the discrete model.
can anyone give some clue what is wrong ?
best wishes.
Old   May 1, 2009, 14:10
O.D.Y.'s Avatar
Hi there, I have the same problem now.... same error, did you find any solution?
cheers
Old   May 1, 2009, 15:36
R. Roy
dear sir,
i had since then modfied the code.
the nan however when something in denominator goes 0 or you have a negative exponent.
if you look into those areas, may be it can solve your problem.
i will look of i can help you with this any further if you can paste the code snippet.
good luck.
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
