Udf calling into Fluent
Hi everybody,
I need your help in calling a source file.c into Fluent. When I call my udf into Fluent and build it, the following message appears and I am not able to load it into the library: Creating library libudf.lib and object libudf.exp my_herschel_bulkley.obj : error LNK2019: unresolved external symbol __imp__Cell_Strain_Rate_Mag referenced in function _my_herschel_bulkley libudf.dll : fatal error LNK1120: 1 unresolved externals Could anyone please help me with that?Any help will be greatly appreciated. Waiting from you very soon. Thanks. |
hai
this error may come because you are using some command variables which has not been called by rhe header file |
Yes. The problem was was exatcly about that. I then fixed the error. Thank you.
