-   Fluent UDF and Scheme Programming (https://www.cfd-online.com/Forums/fluent-udf/)
-   -   Parallelizing a udf: How can I share my directory? (https://www.cfd-online.com/Forums/fluent-udf/64285-parallelizing-udf-how-can-i-share-my-directory.html)
coolengineer May 6, 2009 03:53
Hi all,
When I loaded my udf into parallel Fluent: The following message appeared:
Error:open_udf_library: The system cannot find the path specified.
Error Object:#f
And the message it said that The current directory ... is not shared! This may couse file open issues accross network!
Thank you all.
-mAx- May 6, 2009 06:17
http://hpce.iitm.ac.in/Manuals/Fluen...df/node124.htm
coolengineer May 6, 2009 10:13
Thank you mAx. You again try to help me. And that document is very helpful. I will let you know if I solve out my problem.
Best,
Originally Posted by -mAx- (Post 215291)
friends.sk July 22, 2009 11:23
Hi, The link is not working ..
- SK.
I need some help in parallelizing udf.. can someone help me.
