Parallelizing a udf: How can I share my directory? |
May 6, 2009, 03:53 |
Jack nedermans
When I loaded my udf into parallel Fluent: The following message appeared: Errorpen_udf_library: The system cannot find the path specified. Error Object:#f And the message it said that The current directory ... is not shared! This may couse file open issues accross network! How can I share my directory? Thank you all. |
May 6, 2009, 06:17 |
Maxime Perelli
Rep Power: 41 |
In memory of my friend Hervé: CFD engineer & freerider |
May 6, 2009, 10:13 |
#3 | |
Jack nedermans
Thank you mAx. You again try to help me. And that document is very helpful. I will let you know if I solve out my problem.
Best, Quote:
July 22, 2009, 11:23 |
SK
Hi, The link is not working ..
- SK. I need some help in parallelizing udf.. can someone help me. |
parallel computing |
problem loading UDF library in parallel cluster | Veera Gutti | FLUENT | 8 | July 26, 2016 07:24 |
Parallelizing a udf | coolengineer | Fluent UDF and Scheme Programming | 4 | February 27, 2013 05:15 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
please please i need urgent helps | ahmed | FLUENT | 3 | August 22, 2007 03:12 |
