May 18, 2009, 12:32 |
host_to_node data transfer
Ellen
Rep Power: 17 |
I need to transfer a 2-d array from the host to nodes, but I didn't find any such examples in the udf manual. suppose my array is A[20][4], how should I write for this: host_to_node_real(A, 20,4)? could anyone please help me on this? Thank you so much. ellen |
May 19, 2009, 04:33 |
Max
Rep Power: 17 |
Hello Ellen,
i guess you have to split your multi-dimensional array into e.g. 4 1-d arrays of length 20 and use the common host-to-node macros. Each node will have to resemble the full array again. This is really nasty, thus if you find a more elegant way let me know. cheers |
May 19, 2009, 12:46 |
Rep Power: 17 |
I think serial data transfer method using standard macros located inside a loop structure can be used. If you dont have a solution yet you can try this. regards |
May 19, 2009, 16:37 |
Ellen
Rep Power: 17 |
thank you for your reply, coglione. There seems to be no direct way for this transfer operation... I'll convert my 2d array as you suggested then.
thanks, ellen |
May 19, 2009, 16:41 |
Ellen
Rep Power: 17 |
I just saw your reply, gemini, thanks. but I'm not quite sure how to carry out your suggested method, could you elaborate more or give an example?
thank you. |
May 30, 2009, 11:34 |
#6 | |
Rep Power: 17 |
Hi ElllenW, I'm sorry, I don't have a ready example for you, however, you can start with the section titled as "7.5.8 Message Passing Macros" in UDF manual (/help/html/udf/node214.htm) in which low-level message passing macros are described and there is an example about data transfer between nodes and between node0 and host. I think that section will be helpful. Btw, if I reach any example about your case, I'll write here. Good luck |
Data Transfer - Polyflow to Fluent to Abaqus | Bob Carson | FLUENT | 0 | March 27, 2007 09:31 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
Star to Nastran/Patran Data Transfer | A.S. | Siemens | 0 | February 14, 2005 08:08 |
Transfer data in MPI | hall | Main CFD Forum | 0 | May 3, 2004 18:57 |
Data transfer | H. P. LIU | Main CFD Forum | 5 | May 19, 2003 10:47 |
