-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Problem with UDF on a Linux machine (Red Hat) (http://www.cfd-online.com/Forums/fluent-udf/65233-problem-udf-linux-machine-red-hat.html)
Iaroslav June 9, 2009 10:55
Hello everyone,
I have written a simple UDF (DEFINE_TURBULENT_VISCOSITY) to modify the eddy viscosity calculated by the standard k-e model. I have run several simulations in Windows Vista with Fluent interpreting my UDF with no problems at all. However, when I try to run the same simulation on the Linux machine (Red Hat) I am getting an eeror message that informs me of a syntax error on line 2. Here is my UDF:
#include "udf.h"
DEFINE_TURBULENT_VISCOSITY(custom_mu_t, c, t)
real mu_t;
real s_11;
real s_12;
real s_22;
real s_g;
real div_vel;
real mach_g;
real l_g;
real alpha;
real c_mu;
real rho = C_R(c,t);
real k = C_K(c,t);
real d = C_D(c,t);
real temper = C_T(c,t);
real dudx = C_DUDX(c,t);
real dvdy = C_DVDY(c,t);
real dudy = C_DUDY(c,t);
real dvdx = C_DVDX(c,t);
s_11 = dudx;
s_22 = dvdy;
s_12 = 0.5*(dudy+dvdx);
div_vel = dudx+dvdy;
s_g = sqrt(2*((SQR(s_11)+2*SQR(s_12)+SQR(s_22))-1/3*SQR(div_vel)));
alpha = sqrt(1.4*287*temper);
l_g = 0.09*pow(k,1.5)/d;
mach_g = s_g*l_g/alpha;
c_mu = 0.07*exp(-0.4*mach_g);
mu_t = c_mu*rho*SQR(k)/d;
return mu_t;
Any help would really be appreciated as my Linux machine is much better at running simulations than my Windows laptop.
Thank you,
Iaroslav
gemini June 9, 2009 13:20
try
dos2unix filename
command in console. it may help to you.
try web search for dos2unix for its description
Iaroslav June 9, 2009 14:07
Thanks for the reply.
Unfortunately this did not solve my problem. First, I get the message "problems converting file mu_t.c" and then I get the same error message "syntax error on line 2". Furthermore, I don't know why this is happening in the first place since its a c course file and the only header I am using is udf.h.
Thanks,
Iaroslav
gemini June 9, 2009 14:20
I copied your function and it was was succesfully intepereted by FLUENT on my machine (64 bit OpenSUSE 11.1 on AMDX2-7750 4GBRAM). Maybe you should try another computer.
Regards.
Gemini
Iaroslav June 9, 2009 14:38
Thank you for the help Gemini,
I got it working my creating a completely new C file on my Linux system.
Many thanks,
Iaroslav
spring May 12, 2010 07:43
same problem
Hi Iaroslave,
I have the same problem. I got a udf file which I wrote in a text file with the ending .c, so that it would become a C file. When interpreting it in fluent in windows XP it is interpreted with no problems. But when I try to interpret it in fluent in linux it always shows me a syntax error in line 1, which by the way is empty.
Here is the code:
UDFprofile3D.c
UDF for specifying a steady-state velocity profile boundary condition
#include "udf.h" /* must be at the beginning of every UDF */
/* constants: */
#define R 8. /* inlet radius [mm] (with actual scaling in Fluent applied!) */
#define VFLOW 15. /* effective volume flow [l/min] */
#define POWER 1./7. /* 1/7 power law defining turbulent profile */
DEFINE_PROFILE(velocity_y,thread,index)
double PI;
real Umax; /* maximal inlet velocity */
real x[ND_ND]; /* this will hold the position vector every single face centroid */
real r;
face_t f;
PI = acos(-1.);
Umax = pow(10.,3.)*VFLOW/PI/pow((R),2.)/49.;
begin_f_loop(f,thread) /* loops over all faces in the thread passed
in the DEFINE macro argument */
F_CENTROID(x,f,thread);
r = sqrt(pow((1000*x[0]),2.)+pow((1000*x[2]),2.));
F_PROFILE(f,thread,index) = Umax*pow((1.-r/R),POWER);
end_f_loop(f,thread)
You said, that you solved this problem by writing a complete new C file in linux. I opend a file and copied my code into this file and then I added the ending .c, but it still doesn't work when I try to interprete it. Did I do something wrong? Can you please tell me in detail how you solved your problem, because I have EXACTLY the same problem you had.
And I also need to work on the linux machine because it is faster in running simulations (although I realy hate hate hate linux!).
Thanks,...
