-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   How to calculate the curvature in UDF (http://www.cfd-online.com/Forums/fluent-udf/66199-how-calculate-curvature-udf.html)
Xinqiang July 8, 2009 21:04
1 Attachment(s)
I use VOF model to simulate the liquid-vapor two phase flow. I want to get the interface curvature by udf, but I don't know how to write the equation (showed as attachment) in udf. If you know how to deal with this, could you give me some suggestion? Thanks
Xinqiang
shiraz_man67 January 4, 2013 04:48
I have same problem too I want to implement disjoining pressure and I need surface curvature of each cell:confused:
vig January 24, 2013 21:06
You could access the curvature by the following
- Use solve>set>expert option for keeping the temporary memory from being freed [yes]
- Then Use SV_C_TMP_0 in the udf to access the value of curvature.
( This would give you the value of secondary phase curvature)
- Not always safe as this is the temporary variable and you access the values being last stored in this variable. So check before using it.
syavash February 10, 2013 20:39
I suppose that there might be another way,
Saving C_VOF(c,t) into C_UDSI and extracting gradient by C_UDSI_G
Goodluck
vig February 15, 2013 06:17
Volume fraction is discontinuous, therefore you would require to smoothen the volume fraction field before the calculation of gradient and curvature.
shashank312 July 29, 2013 14:32
Is there a way to calculate curvature apart from using the SV_C_TMP_0 macro? I'm sure there must be a way to calculate divergence of the unit normal vector to the liquid-vapor interface.
cfd^2 January 22, 2016 21:08
What is the real meaning of the macro SV_C_TMP_0? Does it directly access the interface curvature? I did not find details about this macro...
