-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   parse error with interpreting UDF (http://www.cfd-online.com/Forums/fluent-udf/67406-parse-error-interpreting-udf.html)
ivanbuz August 13, 2009 17:40
This is my first UDF, and I am having trouble to interpret it into Fluent. Fluent shows the following error, but I don't know what is wrong.
Error: H:\airfoil_flow\setup_test9_UDF\time_average_press ure_coeff.c: line 23: parse error.
Error: H:\airfoil_flow\setup_test9_UDF\time_average_press ure_coeff.c: line 23: f_loop_last: undeclared variable
See below for the UDF. I am doing unsteady flow around a 3D airfoil, and want to use this UDF to calculate the time-averaged pressure coefficient on the airfoil surface.
/* UDF to compute time-averaged pressure coefficient */
/* be sure to allocate at least two UDM*/
#include "udf.h"
int n=0; /* number of time-step */
int zone_ID=5; /* zone ID of airfoil surface */
DEFINE_EXECUTE_AT_END(time_avr_PC)
Domain *domain = Get_Domain(1);
Thread *t = Lookup_Thread(domain, zone_ID);
real p_ref=0, den_ref=1.225, u_ref=21.911; /* reference pressue, reference density and reference velocity */
real q_ref=1/2*den_ref*u_ref*u_ref; /* reference dynamic pressure */
face_t f;
n++
begin_f_loop(f,t)
F_UMDI(f,t,0)+= F_P(f,t);
F_UDMI(f,t,1)=(F_UMDI(f,t,0)/n - p_ref)/(q_ref);
end_f_loop(f,t)
Thanks for any suggestion!
ivanbuz August 13, 2009 17:53
I got it. I miss the ; behind n++.
and I also fix the typo in line 25 and 26: F_UMDI to F_UDMI.
This is the new version of it.
#include "udf.h"
face_t f;
n++;
begin_f_loop(f, t)
F_UDMI(f,t,0) += F_P(f,t);
F_UDMI(f,t,1) = (F_UDMI(f,t,0)/n - p_ref)/(q_ref);
end_f_loop(f, t)
But I still have problem. Fluent shows error as following while interpreting. Anyone knows what it means?
Error: Set_Thread_Variables: wta(real)
Error Object: ((constant . 1) (profile "" ""))
ivanbuz August 13, 2009 18:29
I got it. it is bacause I read the case and data files into older version of fluent.
