August 13, 2009, 17:40 |
parse error with interpreting UDF
Ivan
Rep Power: 16 |
This is my first UDF, and I am having trouble to interpret it into Fluent. Fluent shows the following error, but I don't know what is wrong.
Error: H:\airfoil_flow\setup_test9_UDF\time_average_press ure_coeff.c: line 23: parse error. Error: H:\airfoil_flow\setup_test9_UDF\time_average_press ure_coeff.c: line 23: f_loop_last: undeclared variable See below for the UDF. I am doing unsteady flow around a 3D airfoil, and want to use this UDF to calculate the time-averaged pressure coefficient on the airfoil surface. /************************************************** **************************/ /* UDF to compute time-averaged pressure coefficient */ /************************************************** **************************/ /* be sure to allocate at least two UDM*/ #include "udf.h" int n=0; /* number of time-step */ int zone_ID=5; /* zone ID of airfoil surface */ DEFINE_EXECUTE_AT_END(time_avr_PC) { Domain *domain = Get_Domain(1); Thread *t = Lookup_Thread(domain, zone_ID); real p_ref=0, den_ref=1.225, u_ref=21.911; /* reference pressue, reference density and reference velocity */ real q_ref=1/2*den_ref*u_ref*u_ref; /* reference dynamic pressure */ face_t f; n++ begin_f_loop(f,t) { F_UMDI(f,t,0)+= F_P(f,t); F_UDMI(f,t,1)=(F_UMDI(f,t,0)/n - p_ref)/(q_ref); } end_f_loop(f,t) } Thanks for any suggestion! |
August 13, 2009, 17:53 |
Ivan
Rep Power: 16 |
I got it. I miss the ; behind n++.
and I also fix the typo in line 25 and 26: F_UMDI to F_UDMI. This is the new version of it. /************************************************** **************************/ /* UDF to compute time-averaged pressure coefficient */ /************************************************** **************************/ /* be sure to allocate at least two UDM*/ #include "udf.h" int n=0; /* number of time-step */ int zone_ID=5; /* zone ID of airfoil surface */ DEFINE_EXECUTE_AT_END(time_avr_PC) { Domain *domain = Get_Domain(1); Thread *t = Lookup_Thread(domain, zone_ID); real p_ref=0, den_ref=1.225, u_ref=21.911; /* reference pressue, reference density and reference velocity */ real q_ref=1/2*den_ref*u_ref*u_ref; /* reference dynamic pressure */ face_t f; n++; begin_f_loop(f, t) { F_UDMI(f,t,0) += F_P(f,t); F_UDMI(f,t,1) = (F_UDMI(f,t,0)/n - p_ref)/(q_ref); } end_f_loop(f, t) } But I still have problem. Fluent shows error as following while interpreting. Anyone knows what it means? Error: Set_Thread_Variables: wta(real) Error Object: ((constant . 1) (profile "" "")) |
August 13, 2009, 18:29 |
Ivan
Rep Power: 16 |
I got it. it is bacause I read the case and data files into older version of fluent.
time average |
Parse Error:- Interpreting UDF on remote terminal | moataz.che | FLUENT | 1 | March 7, 2017 14:13 |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 06:43 |
UDF parse error at profile function line | Wiggy | Fluent UDF and Scheme Programming | 1 | July 27, 2009 15:59 |
Parse Error Message While interpreting UDF in FLUENT | dhimans | Fluent UDF and Scheme Programming | 1 | July 10, 2009 06:29 |
PARSE ERROR Message when interpreting UDF in FLUENT | dhimans | FLUENT | 0 | May 24, 2009 11:40 |
