what's -1.#IND?
Old   February 6, 2013, 10:45
Default what's -1.#IND?
Raymond.Leoi is on a distinguished road
when I ran the following udf for the source of energy, s_p that I defined appears as a weired number, -1.#IND. Then
Error: Divergence detected in AMG solver: temperature
Error Object: #f
Any idea for this problem?
DEFINE_SOURCE(energy_source, cell, thread, dS, eqn)
real source;
real s_j, s_p;
s_j = -C_UDSI_DIFF(cell,thread,0)*NV_MAG2(C_UDSI_G(cell,t hread,0));
s_p = - C_UDSI_G(cell,thread,2)[0]*C_UDSI_G(cell,thread,0)[0] /
- C_UDSI_G(cell,thread,2)[1]*C_UDSI_G(cell,thread,0)[1] /
- C_UDSI_G(cell,thread,2)[2]*C_UDSI_G(cell,thread,0)[2];
s_p = -s_p*C_T(cell,thread)*C_UDSI_DIFF(cell,thread,0);
/* s_p = 0.; */
printf("s_j: %g\n", s_j);
printf("s_p: %g\n", s_p);
source = s_j + s_p;
dS[eqn] = 0.0;
return source;
Raymond.Leoi is offline   Reply With Quote
Old   February 6, 2013, 11:24
It seems IND indicates indefinite. However, I already initialize all those gradient in DEFINE_INIT. -1.#IND still comes up. How can I fix it?
Old   February 10, 2013, 19:08
Syavash Asgari
syavash is on a distinguished road
It seems that you have a divide by zero problem, check your UDS value to make sure everything's right.
Goodluck
syavash is offline   Reply With Quote
Old   February 12, 2013, 08:11
akm
akm is on a distinguished road
What do you mean you have initialized the gradients?? C_UDSI_G is calculated by the solver itself, and cannot be initialized by the user.
Your problem might be because the gradients have not been assigned at the beginning of the iterations. You can use an 'if' condition to ensure that the gradients are available, otherwise return a zero source.
if (NULL != THREAD_STORAGE(thread,SV_UDS_I(0)) && NULL != T_STORAGE_R_NV(thread,SV_UDSI_G(0)))
   s_j = ...
   s_p = ...
   source = s_j+s_p;
   dS[eqn]= ...
   return source;
else
  dS[eqn]=0;
  return 0;
Also, i see that you have assigned dS[eqn] = 0. dS[] is the differential of the source term wrt the variable for which the source is given. dS is provided for better convergence.
in your case it should be:
source = s_j + s_p;
dS[eqn] = s_p/C_T(cell,thread);
return source;
akm is offline   Reply With Quote
Old   February 19, 2013, 07:42
Thanks for your suggestion, Akm. DS=0. means that the source term is fedback explicitly.
   s_j = ...
   s_p = ...
   source = s_j+s_p;
   dS[eqn]= ...
   return source;
else
  dS[eqn]=0;
  return 0;
source = s_j + s_p;
return source;
Old   February 20, 2013, 13:11
Raghuvir
Raghuvir is on a distinguished road
Hi,I have a similar problem. I am working on adding a body force to navier stokes equation, which is a function of voltage and charge density.
I added Voltage and charge density as two UDS,0 and 1 respectively. For UDS'0' (volt), I use poissons potential equation i.e., del^2(V) = -rho_q/enod. So,diffusivity is -1 and source term is charge_density/e_nod. For UDS'1', I use charge conservation equation. i.e., grad(charge_density*mu_constant*E) = 0 where E = -grad(V). So, I use flux equation, calculate gradv term at face by taking average of two neighbour cells or zero if its boundary.
UDS-0 :-
source = -( C_UDSI(c,t,1) ) / (8.8514e-12) ;
dS[eqn] = 0 ;
return source ;
UDS-1:-
NV_VS_VS(fluxvec, =, C_UDSI_G(c0,t0,0), * , 0.5, + , C_UDSI_G (c1,t1,0) , * , 0.5 ) ;
flux = -NV_DOT(fluxvec, A)*2e-4; /* Average flux through face */
return flux;
Model :-
two electrodes surrounded by air. one electrode with 27k volt and charge density as 0.016. another electrode with 0 volt and o charge density.
PROBLEM :-
I get Nan values for UDS-1 (charge density) when I initialise it with anything except zero. If I initialise UDS-1 with 0 then the residual monitors of UDS-1 instantly go to e-43 values. But I see changes in UDS scalars only near electrodes and near domain boundaries, rest of the domain has constant UDS values.
I Tried
initialising without udf and then adding them after some iterations....but no luck.
I am guessing its sth to do with flux equation in that UDS-1 equation. Could anyone please help me with finding the error.
Raghuvir is offline   Reply With Quote
lift coefficient -1.#IND arashm FLUENT 0 July 28, 2010 11:13
