parallel mode failure in 3ddp but not in 2ddp
hello,
I have been using 2ddp mode in FLUENT to simulate a problem which involves two UDSs and some other source terms on the momentum equation, so far everything has worked fine in 2d, both in serial and parallel mode. The domain is a simple square, top and bottom boundaries are walls, left and right are a periodic pair. I now want to run a 3d problem, which is a cube, so that now the top and bottom faces are walls and the other 4 boundaries are periodic pairs. When I run the problem in 3ddp serial it is fine, however in 3ddp parallel the following error comes up, its strange that it works in 2ddp in parallel but not in 3ddp, does anyone know why?: received suspend command for a pmi context that doesn't exist: unmatched id=1 999999(..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory The Parallel FLUENT process could not be started Thanks a lot akour |
