Home > Forums > Fluent UDF and Scheme Programming
turbulent viscosity UDF!please your help
Like Tree3Likes
Old   October 29, 2009, 13:17
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
First see if you get the right values from C_WALL_DIST macro. If not, then it is rather simple to write your own udf that computes this distance using the BOUNDARY_FACE_GEOMETRY macro.
Dragos
joy2000 likes this.
dmoroian is offline   Reply With Quote
Old   October 29, 2009, 13:21
Vivek Sampath
vsampath is on a distinguished road
Thanks a lot.....
I tried the C_WALL_DIST.... the udf compiles but when initaliasing it shows error....... I will try with the Boundary_FACE_geometry..... where can i find an example on how to use that??
vsampath is offline   Reply With Quote
Old   October 29, 2009, 13:46
dmoroian's Avatar
Dragos
I wouldn't give up using C_WALL_DIST macro. What error do you get? Could you post your udf? There is an error in your previous posted code.
Try first your code changing the line:
y=C_WALL_DIST(c,t);
with:
y=C_WALL_DIST(cell,thread);
...I hope you understand the error...
However, here is an untested example of how to compute it your self (should be valid for Gina, too):
real wallDist(cell_t c, Thread *t)
   real A[ND_ND], es[ND_ND], dr0[ND_ND];
   real ds, A_by_es;
   real y;
   int n;
   face_t f;
   Thread *tf;
   c_face_loop(c, t, n)         /* loops over all faces of a cell */
      f = C_FACE(c,t,n);
      tf = C_FACE_THREAD(c,t,n);
      if(BOUNDARY_FACE_P(tf)) /* if the face is on boundary */
         BOUNDARY_FACE_GEOMETRY(f,tf,A,ds,es,A_by_es,dr0);
         y = NV_DOT(es,dr0);
         return y;
   return 0;
Dragos
mm.abdollahzadeh likes this.
Old   November 1, 2009, 16:04
gina
gina is on a distinguished road
Hi Vivek,
can you find any solution for your udf?
for me, I could not turn it to have good results
gina is offline   Reply With Quote
Old   November 1, 2009, 16:36
gina
there is someone who can help me?
I would like to know whether a UDF turbulent viscosity permits me to provide a turbulent viscosity profile where the turbulent visosity is a function of wall normal distance y.
I know that, i must calculate the wall normal distance and define turbulent viscosity as a function of the distance.
but how to do this?? I AM NEW IN UDF ALSO IN C PROGRAMATION.....
please i need some help
Old   November 2, 2009, 01:46
dmoroian's Avatar
Dragos
Hi Gina,
I think your approach should work if you are using a low Re turbulence model (meaning without wall functions). Did you check if the C_WALL_DIST gives you the right values?
Dragos
Old   November 2, 2009, 16:31
gina
hi Dragos,
I use k-e model with enhanced wall treatment.
my Reynolds number= 5400.
Gina
Old   November 2, 2009, 18:28
dmoroian's Avatar
Dragos
Do you have enough resolution near the wall? If you don't then enhanced wall treatment will apply a wall function and your back to what Krishna said before.
If the resolution is enough then what is the error you are complaining about?
Have you checked the C_WALL_DISTANCE macro if it provides the right value?
You can also attach a debugger to your udf and follow it step by step. There is an example on wiki describing how to do this (http://www.cfd-online.com/Wiki/Fluen..._udf_using_gdb).
Dragos
Old   November 3, 2009, 14:05
gina
dear dragos,
yes i have enough resolution near the wall.
no i have not checked the C_WALL_DISTANCE macro if it provides right value, how to do this?
the objective of my udf is to improved the nu_t formula in the near wall region when y_plus<=20.
can you send me your mail @ to explain better what i want to to
thank you
gina
Thread Tools
Trackbacks are On
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Turbulent viscosity in a riser ap FLUENT 8 April 19, 2003 08:00
effective? turbulent? laminar? viscosity MIssNancy FLUENT 3 December 3, 2002 00:53
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
Turbulent viscosity Christian Holm Main CFD Forum 4 June 23, 2001 22:04
