How to get the heat flux of an interior boundary?
My model contains two regions, and I need to know the value of heat flux of the interface between this two regions, how can I get it?
Nobody can do it via any UDFs although mass flux is OK. In Fluent, once iteration is done, the value is thrown out. |
hi,
HVAC: is that true even if you issue the command: solve/set/expert and then answer yes when it asks to free temporary memory?? akour |
'solve/set/expert' setting is for gradient macros(eg., C_T_G or something like that). So even if this setting is done, we can't get heat flux. |
Also you can post process the value of source terms, residuals etc. :cool: |
