-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   macro for accessing particle thermal conductivity (http://www.cfd-online.com/Forums/fluent-udf/69535-macro-accessing-particle-thermal-conductivity.html)
yingying October 26, 2009 15:55
In solving a spray problem, I need to change the particle's thermal conductivity during the calculation. I tried to do this through a udf, but I couldn't find the macro for accessing this property in the UDF manual (I assume it would be something like P_Thermal_Conductivity(p), or DPM_Thermal_conductivity(p)).
Does anybody know this macro, or, could you please tell me whether this is the right way to do it?
Thanks a lot.
ying
t.krishnamohan October 26, 2009 21:33
I think you can manage with DEFINE_PROPERTY macro and assign it to the discrete phase material in the material window.
Bye,
yingying October 27, 2009 09:33
Thanks for your reply, Krishna. But with DEFINE_DPM_PROPERTY, I need to hook it to the material panel manually, but what I want to do is to change this particle property during the run. Any ideas? thank you!
ying
mvf July 15, 2010 04:34
do you find your answer ?
Hi
I am looking for a suitable macro for effective conductivity in dpm approach. if you solve your problem, pls help me.
thank you
