-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   'Set Environment Variables' for Fluent 12 (http://www.cfd-online.com/Forums/fluent-udf/70013-set-environment-variables-fluent-12-a.html)
DarrenC November 11, 2009 21:00
Hi ppl,
I am having problems setting Fluent 12 up to run from the command prompt. Ive searched high and low and couldnt find the solution im after. Most of the solutions to solve this problem is to look for a 'Set Environment Variables' link in Start>All programs>fluent folder but I dont have this. Is there a manual way to declare these environment variables so that i can run Fluent 12 from the command prompt? Note that I have to launch fluent 12 from the c:\working directory
Thanks in advance.
VT_Bromley May 25, 2011 10:00
I'm running into the same issue, I cannot find how to "Set Enviornment" as explained in the users guide. This is needed to launch fluent from the command prompt.
Amir May 25, 2011 15:51
follow this:
~\ntbin\ntx86\setenv.exe
