-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   Help with UDF (http://www.cfd-online.com/Forums/fluent-udf/70201-help-udf.html)
mayur November 17, 2009 04:24
Help with UDF
Dear Sir/Madam
I am trying to simulate the compression stroke inside the cylinder. I need to specify a UDF for Injection from 310 degrees to 340 Degrees. I have to activate my inlet during this period.
Can you please guide me in writing an UDF. I have no experience in Programming :(
Thank you
dmoroian November 25, 2009 06:57
Check this post: http://www.cfd-online.com/Forums/flu...tml#post237366
raoudha November 25, 2009 07:59
dear dmoroian
i'm simulating slug flow with phase change (boiling heat transfer) in vertical tube and i need also to specify a UDF for mass and heat transfer between gas and liquid phases, would please help me
dmoroian November 25, 2009 08:11
Hi Raoudha,
Your topic is difficult, and I don't have much experience with it (mass transfer between phases). As a general answer you have to use DEFINE_SOURCE macro.
raoudha November 25, 2009 08:21
thank you dmoroian
raoudha November 27, 2009 10:56
hello dmoroian
i'm trying to understand how using udf for boiling flow (horizontal boiling flow) but when compiling (define-> udf->compiled) an error msg is shown: the system cannot find the path specified (the boiling.c file was saved in the same directory)
"(system "copy C:\Fluent.Inc\fluent6.2.16\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 fichier(s) copi‚(s).
0
(chdir "libudf")()
(chdir "ntx86\2ddp")()
'nmake' n'est pas reconnu en tant que commande interne
ou externe, un programme ex‚cutable ou un fichier de commandes.
Done."
what shall i do
thank in advance
raoudha
dmoroian November 28, 2009 04:59
You need a compiler
Hi Raoudha,
From the message you posted above I suspect that you don't have a compiler installed on your machine.
Dragos
raoudha November 28, 2009 05:35
hi dragos
i have installed c++ but the same msg is chown,
shall i use an other compiler?
thankx
raoudha
dmoroian November 28, 2009 11:46
I have never used fluent+udf on Windows, but Microsoft Visual C++ should be enough. Do you have it installed?
Dragos
raoudha November 28, 2009 12:20
yes i have installed Microsoft Visual C++2008 express edition
and no change :-((
raoudha November 28, 2009 13:51
finally this problem is solved, i had to open fluent from Visual Studio command prompt
thank for help
raoudha
sabbasi_mr December 2, 2009 00:23
some times the the nmake problem is solved, but other problems exist. It is better to counteract all problem at once:
Run the Vcvars32.bat file in the ..\BIN directory found in the installed directory under ..\MSDEV or ..\DevStudio\VC of your installed visual c++ directory. This file contains the environment variables required to run build tools from a command prompt.
After that run the fluent from this command prompt......
raoudha December 2, 2009 05:47
hello Saeed
i'll try to do it
thankx
famangs December 15, 2013 08:04
UDF rotation for a VAWT
1 Attachment(s)
i want to do a simulation of a vawt using UDF with "Fluent" but i have some problem. I want that the blades move only with the wind velocity.
When i use a dynamic mesh, i have the message" negative volume" in "unsteady solver" but in "steady" i have solution.
Someone can help me. i send also the picture of my study
my udf:
DEFINE_CG_MOTION(piston,dt,vel,omega,time,dtime)
Thread *t;
face_t f;
real NV_VEC(A);
real force, dv;
/* reset velocities */
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P())
return;
/* get the thread pointer for which this motion is defined */
t = DT_THREAD(dt);
/* compute pressure force on body by looping through all faces */
force = 0.0;
begin_f_loop(f,t)
F_AREA(A,f,t);
force += F_P(f,t) * NV_MAG(A);
end_f_loop(f,t)
/* compute change in velocity, i.e., dv = F * dt / mass
velocity update using explicit Euler formula */
dv = dtime * force / 50.0;
v_prev += dv;
Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev,
force);
/* set x-component of velocity */
vel[0] = v_prev;
dmoroian December 15, 2013 11:46
You need to study more
Hello Famangs,
I don't know what a "vawt" is, so I looked at your picture, and it seems that you have a rotating part and a static part separated by an interface. I presume that you want to move only the rotor by rotating it around an axis. The rotation will be given by a resultant pressure force.
According to my view, these are the errors that you made:
1. The force should be vectorial not scalar. The summation you do, should be accurate only for a plannar surface.
2. You need to modify angular velocity (omega), not translational velocity, otherwise your rotating part will go out of its axis.
These errors are mostly conceptual, so I would advise you to ask for help from your supervisor, or study more.
famangs December 16, 2013 04:30
Hello, dmoroian,
thanks for your reply, it's the first time that i use the udf. I have a lot of difficulty with it. VAWT means vertical axis wind turbine
