Smooth a mesh with UDF
Old   December 1, 2009, 15:11
Default Smooth a mesh with UDF
Acoidan Betancort Mondesdeoca
AcoidanBM is on a distinguished road
Hi there.
I'm trying to automate the analysis processing in Fluent because I have to make a lot of analysis. For this reason I'm working with a journal file.
The problem is that each problem has its own mesh. If I want to smooth the mesh before running the analysis, it's not always the same. I mean, each mesh is different, so the smooth process will be differente as well.
So I was thinking about using the UDF tool, in order to do that.
What do you think? Is it possible?
Thank you very much
AcoidanBM is offline   Reply With Quote
Old   December 3, 2009, 02:25
Default Not with udf
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello Acoidan,
I'm not aware of any documented way to call this kind of functions (smooth-mesh) from a udf.
However, fluent has an implementation of a fully capable programming language called scheme that you can use instead of C. Check this on wiki: Fluent Environment
Dragos
dmoroian is offline   Reply With Quote
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
Help! sub-iterations, Dynamic Mesh or UDF Claudi FLUENT 0 January 19, 2007 03:07
UDF macros and updated mesh geometry Maziar Mahzari FLUENT 1 November 1, 2005 06:29
a problem about DEFINE_GEOM in dynamic mesh UDF speedcat FLUENT 1 May 16, 2005 03:09
