UDF inlet velocity profile mismatch with Fluent
I am prescribing a velocity profile at the inlet of my mesh. Fluent compiles the c file fine and the solution does converge. However, the velocity profile that I am inputting is a parabola and Fluent does not plot the correct shape of my profile at the inlet. My UDF code is show below. My y coordinates start at zero and goes to 0.0093 m.
Any ideas on why Fluent is not interpreting the correct velocity profile would be appreciated. #include "udf.h" #include "mem.h" /** Parameter Constants **/ #define wallspeed 7.0711 #define finalheight 0.0093 #define height 0.001 /***************** Inlet Velocity Profile in Slot *****************/ DEFINE_PROFILE(inlet_velocity_profile,thread,posit ion) { real x[ND_ND]; real y; face_t f; begin_f_loop(f,thread) { F_CENTROID(x,f,thread); y = fabs(x[1]); F_PROFILE(f,thread,position) = wallspeed*(((6/(finalheight*finalheight))*((1/2)-(height/finalheight))*((y*y)-(finalheight*y)))-(y/finalheight)+1); } end_f_loop(f,thread) } |
profile in the velocity inlet
hi...
did you solve your problem, i have this problem,too. thanks, elahe |
Ohhhh,
There is problem in your geometry creation. Remember the velocity profile given for pipe, y= something something... for e.g the pipe is of diameter 1m on y axis. you should construct it as (y=+0.5 and y=-0.5 and centre of pipe should be at "zero") either you can make changes in udf but i feel that is tidious(not that much). Amol |
hi Goldsstean
thanks for your attention it's a bit odd, my case is a canal and i want to make wave in that. 'y' in my case is calculate from the bottom of canal , is different with pipe,ya? do you try yoursef? i try your idea.... best elahe |
Could you please explain your problem in detail.
i model a canal with 20 m lenght and 15 m height in 2d fluent.
i wanna generate wave in canal and i hook a udf file that velocity time varing was defined in it for x and y direction. wave is generated correctly but velocity profile plot is not correct and do not match with velocity countor. it seems velocity countor is right and match with theory but profile is wrong. i set velocity inlet in the left border of canal. and in plot menu >xy plot> i write a file of velocity in this boundary. is my way right or not? thanks in advance elahe |
how do give parabolic inlet velocity
how do give parabolic inlet velocity profile for supersonic nozzle
udf for velocity profile
dear all, i am new in fluent simulation. I write a udf file to define a terrain for my case. I use log law for velocity but I face to this massage: " number error floatingpoint error" .
would you please help me.:( this is my udf file: #include "udf.h" DEFINE_PROFILE(log_velocity,thread,position) { real x[ND_ND]; real y; face_t f; begin_f_loop(f,thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f,thread,position) = 5*log(y/0.4)/log(10/0.4); } end_f_loop(f,thread) } |
UDF for density variation
Please help me in making a UDF for following condition=
Variable density was defined in the liquid state as q = ql/[b(T - Tl) + 1] for 30C < T < 100 C, where q = 760 kg/m3, Tl = 30 C, and b = 0.0005 , with linearly varying density in the ‘‘mushy” state, from 870 kg/m3 at 28 C to 760 kg/m3 at 30 C. |
Do u get the solution to your problem? I am also getting the same problem but in giving the transient temperature profile.
Any help would be appreciated. |
open channel problem
2 Attachment(s)
Hi everybody,
I have a problem with the wind pressure distribution on a building. As you can see from the attached picture (Picture 1), which I downloaded it from the internet, the pressure at the lower part of the building is much less than that at the upper part and this is expected to be happened because the wind velocity near the ground is much less than that at the top. The problem I faced is that the wind pressure be the same along the height of the building (Picture 2). Does anyone can help me? |
Hi Muhamed,
You need to define a velocity profile the varies with height at the inlet using a UDF. I would also suggest that you refine the mesh near the building. By the way, do you happen to know the source for Picture 1? Thanks Y.A.Z |
Do you have a UDF for inlet velocity profile in an open channel? I couldn't find it in the INTERNET and I don't know how to write the UDF that I need. Regarding Picture 1, as I remember, I took it from an article about air velocity distribution on a building. |
Here is a UDF for defining a velocity profile along a boundary for wind modelling around buildings: http://www.cfd-online.com/Forums/flu...nd-height.html
Edit the following equation to your inlet velocity profile (z is the z-direction height in their UDF): Code:
F_PROFILE(f, thread, position) = 24.9 *pow(z,0.27); |
