URGENT!!! F_UDSI at symmetry boundary
In FLUENT udf manual following statement is given, Quote:
Then, I tried to test this in a simple 3D uds diffusion problem where the domain has symmetry boundary condition. After convergence, I applied following function to printout the face values of uds at all boundaries: Code:
face_t f; thanks [/COLOR] |
#include "udf.h" DEFINE_ON_DEMAND(test) { face_t f; cell_t c0; Thread *tf,*t0; Domain*domain=Get_Domain(1); real NV_VEC(dist_vector); real f_centoid[ND_ND],c_centroid[ND_ND]; real face_value,cell_value; thread_loop_f(tf, domain)/* loops over all face threads in a domain*/ { if (THREAD_F_AXIS==THREAD_TYPE(tf)) /* if the thread is an axis thread*/ { begin_f_loop(f, tf) /* loops over faces in a face thread */ { F_CENTROID(f_centoid,f,tf); //centroid of a face c0=F_C0(f,tf); t0=THREAD_T0(tf); C_CENTROID(c_centroid,c0,t0); //centroid of the neighbour cell NV_DD(dist_vector,=,f_centoid[0],f_centoid[1],0,-,c_centroid[0],c_centroid[1],0); face_value=C_UDSI(c0,t0,0)+NV_DOT(C_UDSI_G(c0,t0,0 ),dist_vector); cell_value=C_UDSI(c0,t0,0); Message0("x coord.=%g,face value=%g,cell value=%g\n",f_centoid[0],face_value,cell_value); } end_f_loop(f, f_thread) } } } |
Can your script be used for calculation of face value at the interior faces by just removing the following line? if (THREAD_F_AXIS==THREAD_TYPE(tf)) /* if the thread is an axis thread*/ Also, THREAD_F_AXIS didn't worked for SYMMETRY bc's. Instead "THREAD_F_SYMMETRIC" works well... Thanks. |
Your script was very useful, and as you said, it can be used for calculating face fluxes of UDS and then they can be used anywhere in your model. thanks again. |
