URGENT!!! F_UDSI at symmetry boundary
Old   March 4, 2010, 15:41
Exclamation URGENT!!! F_UDSI at symmetry boundary
gemini is on a distinguished road
In FLUENT udf manual following statement is given,
Note that F_UDSI is available for wall and flow boundary faces, only. If a UDS attempts to access any other face zone, then an error will result.
Then, I tried to test this in a simple 3D uds diffusion problem where the domain has symmetry boundary condition. After convergence, I applied following function to printout the face values of uds at all boundaries:
face_t f;
Thread *tf;
thread_loop_f(tf, domain)/* loops over all face threads in a domain*/
   begin_f_loop(f, tf)    /* loops over faces in a face thread  */
     if (BOUNDARY_FACE_THREAD_P(tf))
           Message("face id = %d, UDS0 value = %12.5e",f, F_UDSI(f, tf, 0));
   end_f_loop(f, f_thread)
However, execution of this script resulted in an error. So, is there any way to prevent the use of F_UDSI at symmetry bc's? or How can I extract the type of bc of a particular boundary face?
thanks
[/COLOR]
gemini is offline   Reply With Quote
Old   March 8, 2010, 04:51
gearboy is on a distinguished road
Originally Posted by gemini View Post
face_t f;
Thread *tf;
thanks
[/COLOR]
It seems that there are no values stored on the non-wall boundary. This has been also an question confusing me. Maybe it's a bug of Fluent. If it is urgent for you , you can use the following better-than-nothing solution. It uses the neighbour cell's uds value , uds gradient, and distance vector to calculate the face value.
#include "udf.h"
DEFINE_ON_DEMAND(test)
face_t f;
cell_t c0;
Thread *tf,*t0;
Domain*domain=Get_Domain(1);
real NV_VEC(dist_vector);
real f_centoid[ND_ND],c_centroid[ND_ND];
real face_value,cell_value;
if (THREAD_F_AXIS==THREAD_TYPE(tf)) /* if the thread is an axis thread*/
F_CENTROID(f_centoid,f,tf); //centroid of a face
c0=F_C0(f,tf);
t0=THREAD_T0(tf);
C_CENTROID(c_centroid,c0,t0); //centroid of the neighbour cell
NV_DD(dist_vector,=,f_centoid[0],f_centoid[1],0,-,c_centroid[0],c_centroid[1],0);
face_value=C_UDSI(c0,t0,0)+NV_DOT(C_UDSI_G(c0,t0,0 ),dist_vector);
cell_value=C_UDSI(c0,t0,0);
Message0("x coord.=%g,face value=%g,cell value=%g\n",f_centoid[0],face_value,cell_value);
gearboy is offline   Reply With Quote
Old   March 10, 2010, 03:20
#include "udf.h"
face_t f;
cell_t c0;
Thread *tf,*t0;
c0=F_C0(f,tf);
t0=THREAD_T0(tf);
Can your script be used for calculation of face value at the interior faces by just removing the following line?
Also, THREAD_F_AXIS didn't worked for SYMMETRY bc's. Instead "THREAD_F_SYMMETRIC" works well...
Thanks.
Old   March 10, 2010, 21:50
Thanks.
The script can be used for interior faces if the F_T macro doesn't work. And I misunderstood the case as an axial symmetric one. Sorry.
Old   March 11, 2010, 01:23
Cool
Your script was very useful, and as you said, it can be used for calculating face fluxes of UDS and then they can be used anywhere in your model.
thanks again.
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 05:58
Symmetry and boundary conditions eric FLUENT 3 August 30, 2012 09:09
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
Normal velocity at the symmetry boundary Seventy FLUENT 1 October 26, 2009 06:52
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
