HELP:Fluent UDF
The fluent udf manuall has a example "DEFINE_ON_DEMAND(get_coords)".When I use it, it can compile, but confronts error after execute on demand. As follow:
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () I don't know why,please tell me if you know it. Thank you! The programm as follow: #include "udf.h" FILE *fout; void Print_Thread_Face_Centroids(Domain *domain, int id) { real FC[2]; face_t f; Thread *t=Lookup_Thread(domain,id); fprintf(fout,"thread id %d\n",id); begin_f_loop(f,t) { F_CENTROID(FC,f,t); fprintf(fout,"f%d %g %g %g\n",f,FC[0],FC[1],FC[2]); } end_f_loop(f,t) fprintf(fout,"\n"); } DEFINE_ON_DEMAND(get_coords) { Domain *domain; fout=fopen("faces.out","w"); Print_Thread_Face_Centroids(domain,4); Print_Thread_Face_Centroids(domain,5); fclose(fout); } |
There is missing something in the function "get_coords"
The domaine variable should be assigned a value. You can add that line below the declaration of domain: domain = Get_Domain(1); So it becomes: DEFINE_ON_DEMAND(get_coords) }{ Domain *domain; domain = Get_Domain(1); fout = fopen("faces.out", "w"); Print_Thread_Face_Centroids(domain, 2); Print_Thread_Face_Centroids(domain, 4); fclose(fout); |
But I have another problem. When I execute it ,the result is only one face centroid. And the thread 2 have 100 faces in my example.Why not all face centroids of the thread 2 ? I hope your reply. |
You previously wrote:
Print_Thread_Face_Centroids(domain,4); Print_Thread_Face_Centroids(domain,5); but I did not copy it correctly and wrote Print_Thread_Face_Centroids(domain,2); Print_Thread_Face_Centroids(domain,4); Can this be the problem? |
