"enum" in UDS stuff
Old   March 25, 2010, 13:32
Default "enum" in UDS stuff
MASOUD
MASOUD is on a distinguished road
What is the meaning of the following codes:
enum
P1,
N_REQUIRED_UDS
DEFINE_ADJUST(p1_adjust, domain)
/* Make sure there are enough user defined-scalars. */
if (n_uds < N_REQUIRED_UDS)
Internal_Error("not enough user-defined scalars allocated");
MASOUD is offline   Reply With Quote
Old   March 25, 2010, 23:30
gearboy is on a distinguished road
enum
P1,
N_REQUIRED_UDS
enum
P1,
N_REQUIRED_UDS
P1=0,N_REQUIRED_UDS=1; see c language primers for enum usage
n_uds is a macro to get the number of uds that have been allocated.
gearboy is offline   Reply With Quote
Old   March 29, 2010, 00:54
MASOUD
Thanks.
Anyway what's the point of using enum?
Plz check the below code what's the "sg.h" for???
I have 2 UDS. I wrote their code in separate files. Should I put their names in both files?
#include "udf.h"
#include "sg.h"
enum
ELECT_CHARGE_UDS,
CARB_CHARGE_UDS,
N_REQUIRED_UDS
static real ACT_AREA=1;
static real REF_EXCH_CURR_A=1;
static real MW_H2=1;
static real REF_CONC=1;
static real BETA=1;
static real ALPHA=1;
static real NO_ELEC=1;
static real EQU_POT_A=1;
static real FARADAY=1;
static real UNI_GAS_CONS=1;
static real STOCH=1;
static real RXN_RATE_A;
static real Z;
static real ZZ;
static real ZZZ;
static real source;
DEFINE_ADJUST(ELECT_CHARGE_UDS, domain)
DEFINE_SOURCE(ELECT_CHARGE_UDS,c,t,dS,eqn)
Z=ACT_AREA*REF_EXCH_CURR_A*pow(((C_YI(c,t,0)*C_R(c ,t)/MW_H2)/REF_CONC),BETA);
ZZ=exp((ALPHA*NO_ELEC*FARADAY*(C_UDSI(c,t,0)-EQU_POT_A))/(UNI_GAS_CONS*C_T(c,t)));
ZZZ=exp((1-ALPHA)*NO_ELEC*FARADAY*(EQU_POT_A-C_UDSI(c,t,0))/(UNI_GAS_CONS*C_T(c,t)));
RXN_RATE_A=Z*(ZZ-ZZZ);
source=(-STOCH/(NO_ELEC*FARADAY))*RXN_RATE_A;
dS[eqn]=0;
return source;
DEFINE_DIFFUSIVITY(ELECT_CHARGE_UDS,c,t,0)
return 1;
UDS Flux Function Choice Yang Chung FLUENT 1 November 17, 2015 01:14
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 07:37
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 08:53
UDS, parameters and computations hedge FLUENT 2 August 16, 2007 05:19
UDS David FLUENT 1 March 21, 2005 11:31
