-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   how to change particle properties using udf? (http://www.cfd-online.com/Forums/fluent-udf/74525-how-change-particle-properties-using-udf.html)
ljp April 2, 2010 09:57
HI all,
In modeling particle spraying, I try to change some of the particle's properties during flight when certain conditions are met. I wrote a udf using DEFINE_DPM_PROPERTY as in the example shown in the udf manual, but then found out that in the dialogue box for setting particle material, only a few properties allow udf (i.e. have the "user-defined function" option in the drop-down list), and others (like the thermal conductivity) do not have this option. So if I need to change the particle's thermal conductivity, what should I do?
thanks in advance!
ljp
