How can I break a fluent calculation?
Old   March 1, 2010, 05:10
Default How can I break a fluent calculation?
Herman
enry is on a distinguished road
Hi, I'm simulating an unsteady flow, and I impose some time steps to FLUENT "a priori"; however my goal is to break FLUENT calculation "a posteriori", under some bond.
So my idea is to to write a UDF that under some bond impose to FLUENT to break the calculation, even if I impose "a priori" the number of time steps, but FLUENT can't read the command "exit" in my UDF.
Can you help me?
Thanks in advance.
enry is offline   Reply With Quote
Old   March 1, 2010, 10:28
Robert
Robert@cfd is on a distinguished road
Hi
Did you try the touch-command?
http://willem.engen.nl/uni/fluent/do...ips-Tricks.pdf
read page 9/10 for further informations
I didnt try it, but maybe it helps.
Greetings
Robert@cfd is offline   Reply With Quote
Old   March 1, 2010, 10:51
Herman
Hi, thanks for your reply.
Maybe it can be useful.
Old   March 5, 2010, 03:22
gemini is on a distinguished road
See section 3.7 Input/Output Macros in UDF manual. It might help...
good luck
gemini is offline   Reply With Quote
Old   March 5, 2010, 04:17
Herman
Thanks!
enry
Old   April 5, 2010, 19:18
Robert
Hi
Did you find a solution to the problem?
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
power and pumping number calculation in "FLUENT" HARI SANKAR FLUENT 1 March 29, 2011 16:20
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Fluent Cd calculation liflu FLUENT 0 October 31, 2009 10:03
