Convert int to char
Old   April 6, 2010, 11:39
Default Convert int to char
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello world.
I haven't found a way of converting an int value to a char-string.
Is that possible with FLUENT UDF's?!
sega
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 6, 2010, 12:28
DoHander is on a distinguished road
Try to use sprintf.
Example:
char a[100];
sprintf(a,"%d",1002);
Now you should have in "a" 1002 as a string. I didn't actually test my above code, so you can expect to have some problems adapting this to a UDF.
Do
DoHander is offline   Reply With Quote
Old   April 7, 2010, 16:04
sega's Avatar
Sebastian Gatzka
Thank you! sprintf() was the right approach!
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 06:35
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
int to char in UDF Paolo Lampitella FLUENT 3 December 11, 2008 05:01
