Home > Forums > Fluent UDF and Scheme Programming
Access Violation Error
Old   April 22, 2010, 12:06
Default Access Violation Error
Avinash
Avin2407 is on a distinguished road
Hi all,
I have written a UDF for turning ON or OFF the heat flux boundary condition on a surface based on temperature.
The problem is a conduction problem and the model is actually generated in Icepak and is to be solved in FLUENT.
I read in the case file and then I interpret my UDF. It doesnt give me any errors whatsoever but then as I try to solve, upon clicking on "initialize", FLUENT gives me the following error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
I would appreciate any guidance as to what this error may mean and whether it signifies an error in my code or is it something to do with the FLUENT software.
Thank you very much !!
Avinash.
Avin2407 is offline   Reply With Quote
Old   April 24, 2010, 17:52
tf
tf_stl is on a distinguished road
I received the same error when I used F_U(f,t) to try and get the velocity of the fluid at the face of my profile when I was trying to model a fan pressure drop. From the documentation, it seems as though FLUENT compartmentalizes its stored variables. The quote from the UDF manual says, "Note that these variables are available only in the segregated solver. In addition, quantities that are returned are available only if the corresponding physical model is active. For example, species mass fraction is available only if species transport has been enabled in the Species Model panel in FLUENT. Definitions for these macros can be found in the referenced header files (e.g., mem.h)."
I'm still trying to find a way to access the variable I need, but I got the same error in the same situation you did when that line of code was in my UDF.
I'd love to hear if you found another way.
Thanks
tf_stl is offline   Reply With Quote
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Access Violation Error sid FLUENT 1 April 20, 2006 12:10
