sliding User-Defined Memories along the mesh
Old   May 29, 2010, 09:09
Default sliding User-Defined Memories along the mesh
ludovic horion
ludohorion is on a distinguished road
Hi all,
I am modelling mass transfer in a domain. The system is composed of a porous medium, and a gas flowing through it.
I defined 10 UDM in my system. Each UDM represents a discretization point of the concentration profile.
To be clear: I have written an UDF that takes as an argument 10 points of a concentration profile, calculates a mass transfer, and gives out the new concentration profile. Each cell of the domain has then its own concentration profile (i.e. its own 10 UDM's).
Now, I would like to simulate of uniform downward motion of all the UDM's in the domain. If you imagine that the mesh is a (50x5 cells) rectangle for example, this means it contains 250 cells, and each cell has an associated concentration profile (i.e. 10UDMs per cell). At time step t=0+dt, I update all UDM's. Then at t = 0+2*dt, I would like to suppress all UDM's of the line 50 of my mesh, I would like to add a new line (line 1) of UDM's with given initial values, and finally I would like to shift all other 48 lines of UDM from one position down.
So now, I have 50x5 new concentration profiles, and then I do the same at the next time step, and so forth...
My question is: how to implement this into FLUENT? I guess I should take advantage of the EXECUTE_AT_END() macro, to do the algorithm at the end of each timestep. But how can I refer explicitly to the UDM's of the top line of the mesh, or to the UDM's of the bottom line of the mesh?
Thank you very much.
Ludovic.
ludohorion is offline   Reply With Quote
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Sliding mesh error alice FLUENT 3 February 21, 2012 05:53
Mesh deformation using user fortran matled CFX 3 February 18, 2010 16:49
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 02:37
