-   Fluent UDF and Scheme Programming (http://www.cfd-online.com/Forums/fluent-udf/)
-   -   mass flow rate inlet udf (http://www.cfd-online.com/Forums/fluent-udf/76754-mass-flow-rate-inlet-udf.html)
alikami June 3, 2010 09:03
i have a case in which mass flow rate increases for 0.5 sec.
anybody , can give a udf for the problem
thanks
regards
ali
Aminullah June 3, 2010 09:17
U've just like my prob. maybe U can figure it out through read the tutorial UDF (note: U've the equation, if U familiar to C language (NOT C++) U an do it easily)
Good Luck...
alikami June 3, 2010 09:58
yes i solved. thanks
one more problem...
how to give particle mass flow rate using udf???
any idea....
regards
ali
elango86 June 4, 2010 13:47
Compiler ?
which compiler are you using.i have dev c++ is it advisable to use this to write the udfs or should i be using just c
