-   Fluent UDF and Scheme Programming (
-   -   Problem with my udf (
july June 18, 2010 12:42
Problem with my udf
Hi all!
I have a question relative to UDF. I have already used UDF before but I have never encountered this problem.
In fact I got the error message "inlet3d.c": line 1: syntax error.
I don't understand because the first line of my udf is just as in any udf I have used # include "udf.h".
I have just changed my Fluent version from 6.3 to 12.1.4. Moreover the problem only appears when I launch my simulations in parallel on a cluster. I have no problem when I open Fluent and interpret my udf directly.
Do I need to add something to my c-code when I launch it in parallel on the cluster? Is it a problem of Fluent version?
Here is my udf:
#include "udf.h"
/* pressure profile */
real b=0.01;
DEFINE_PROFILE(pressure_profile, thread, index)
real x[ND_ND],y;
face_t f;
real u;
begin_f_loop(f, thread)
F_PROFILE(f,thread,index) = 100376.35*pow((1+0.2*(u)*(u)/(1.4*287*293.15)),(1.4/0.4))-101325;
Thanking you in advance for your help.
fox000002 June 19, 2010 13:26
Check line end format of ur UDF file.
Try 'dos2unix filename' before using the file on the cluster.
DoHander June 19, 2010 22:31
Or ... maybe your UDF is not a parallel UDF ...
Since it runs flawlessly on serial Fluent I suppose there is not a syntax problem or an EOL mismatch.
You need to parallelize an UDF in order to properly run in parallel - see Fluent UDF manual there is an entire chapter about parallelizing a serial UDF.
july June 20, 2010 06:56
Thanks for your answers!
fox000002: I have worked on a Linux computer so I don't think the problem comes from the format.
DoHander: I will try what you have told me. However it's strange because yesterday I managed to launch it on the cluster with a simpler mesh so I really don't understand but I'll have a go at parallelizing my udf!
