October 4, 2010, 13:07 |
Setting up a injection cylinder
anonymous
I try to set up a simulation for an injection of a fluent in a cavity. At the moment I try to set up the shrinking of the volume of the injection-cylinder during injection (to press -in an VOF Model- the fluid in the cavity). Probably this is quite simple, but I´m new to the program and it gives me quite a hard time. My thought is to define the movement of the injection-piston as a moving wall at the headboard of the injection-cylinder. Can this model work ? If it works: For shrinking the volume of the cylinder, do I need to write a UDF (I would take the macro "define_Geom" (?)) or is there an easier way, for example with profiles? I was thinking about the moving wall as a face moving in one direction, the mesh of the body adapting to the change. Is that possible ? The geometry of the injection-cylinder is quite simple, only an cuboid with small radiuses over the length. Would be great if someone could help me. |
Display Modes | |
setting up the custom laws for particle injection | ljp | FLUENT | 4 | February 6, 2018 05:59 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Problem with Injection in engine Cylinder | mayur | FLUENT | 8 | January 14, 2010 21:09 |
For setting INJECTION TYPE | MANOJKUMAR | FLUENT | 0 | December 27, 2005 05:08 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
