Home > Forums > Fluent UDF and Scheme Programming
How can I twist a surface with UDF?
Old   July 21, 2010, 11:21
Default How can I twist a surface with UDF? -solved-
Herman
enry is on a distinguished road
Hi all,
I have to twist a surface through mesh-motion. How can I do that? How should I write the UDF? Please help me...
Thanks in advace!
enry is offline   Reply With Quote
Old   July 21, 2010, 16:57
Herman
I solved the problem, with define_grid_motion.
If somebody is interested, here is the UDF.
#include"udf.h"
DEFINE_GRID_MOTION(twist,domain,dt,time,dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
real NV_VEC(axis);
real delta,xaxis,yaxis,teta,xn,yn,dx,dy,H;
int n;
H = 0.1; /*z-dimension of the model*/
teta = 10*3.14/180; /*rotation angle*/
begin_f_loop(f,tf)
f_node_loop(f,tf,n)
v = F_NODE(f,tf,n);
/* update node if the current node has not been previously
visited when looping through previous faces */
if ( NODE_POS_NEED_UPDATE (v))
/* indicate that node position has been update
so that it's not updated more than once */
NODE_POS_UPDATED(v);
xn = cos(teta)*NODE_X(v)-sin(teta)*NODE_Y(v);
yn = sin(teta)*NODE_X(v)+cos(teta)*NODE_Y(v);
dx = xn-NODE_X(v);
dy = yn-NODE_Y(v);
xaxis = dx/sqrt(pow(dx,2) + pow(dy,2));
yaxis = dy/sqrt(pow(dx,2) + pow(dy,2));
NV_D(axis, =, xaxis,yaxis, 0.0);
delta = sqrt(pow(dx,2) + pow(dy,2))*NODE_Z(v)/H;
NV_V_VS(NODE_COORD(v), =, NODE_COORD(v), +, axis,*,delta);
end_f_loop(f,tf);
Old   September 16, 2010, 13:40
Taher
Taher is on a distinguished road
Hey guys.. I need to move a 2D airfoil through certain angle of attack.. now if I dont want to use CG_Motion.. do you think I can do it through GRID_MOTION.. Like may be threading all the nodes across surface and moving them all..
Taher is offline   Reply With Quote
Thread Tools
Trackbacks are On
need help regarding error in surface rxn UDF Ashish Jain FLUENT 0 May 16, 2005 10:43
need help regarding surface reaction UDF Ashish Jain FLUENT 0 May 11, 2005 14:31
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
Patran Volume Meshing Deb CFX 19 April 17, 2003 10:56
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
