(ACCESS_VIOLATION) when i hook my UDF
Old   August 13, 2010, 09:55
Default (ACCESS_VIOLATION) when i hook my UDF
gina
gina is on a distinguished road
Dear all,
I want to add a new K near the wall with the two low reynolds number (Abe and Chang) available in fluent.
this new k work very well with standard k_e but when I use the two low models ans i hok my UDF, FLUENT received fatal signal (ACCESS_VIOLATION).
please, can some one tell me why?!
thank you
gina is offline   Reply With Quote
Old   August 23, 2010, 06:45
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello Gina,
You don't give too many details so as a short answer: access violation means that you want to use a null pointer, or a pointer to a memory zone that is not allocated. What exactly generated this situation is hard to tell, especially without a sample of the code.
My suggestion is to try to run the udf under a debugger (here is an example how to do it: http://www.cfd-online.com/Wiki/Udf_debug), or at least post the code that makes the trouble.
dmoroian is offline   Reply With Quote
hook a compiled DEFINE_ADJUST UDF to FLUENT caloggero Fluent UDF and Scheme Programming 3 December 14, 2012 03:08
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
how to hook this udf shanu FLUENT 1 August 26, 2011 10:48
UDF hook problem in command line mode. Benlong FLUENT 1 November 12, 2007 14:45
UDF hook on the WALL boundary condition Luke FLUENT 0 June 7, 2006 11:54
