error while running the udf
Old   August 26, 2010, 15:29
Default error while running the udf
sugumaran
sugumaran is on a distinguished road
hello everyone....
now the udf is compiling and loading without error...
but while running the simulation at the bigining itself giving error, says
Absolute pressure Limited to 1.0000e+00 in zone 2
Error:> (Greater-than) : invalid argument [2] : wrong type [not a number]
Error object : nan
what it means.. where should i correct..
thanks
sugu
sugumaran is offline   Reply With Quote
HELP! adding a mass source to VOF eqn. by UDF??? ROOZBEH FLUENT 5 December 3, 2016 17:53
I/O of a real value by "DEFINE_RW_FILE" (UDF) Pietro Asinari Fluent UDF and Scheme Programming 1 August 15, 2015 19:08
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
A Loop problem when running UDF in the batch mode Jun Geng FLUENT 3 July 16, 2008 08:34
DEFINE_GEOM UDF Problems Pat FLUENT 0 August 14, 2003 13:16
