Ramp BC per Iteration
Like Tree2Likes
  • 2 Post By coglione
Old   August 25, 2010, 11:21
Default Ramp BC per Iteration
Andy Robertson
AndyR is on a distinguished road
I have a converged Steady State solution. I am running a family of solutions with slightly different boundary conditions. In this case I am varying the swirl at an inlet. For low values of swirl I find that I can use the existing solution simply change the values and keep running. As the absolute value gets large, I find that the amount of change the solution can absorb without diverging gets small. Even with signifcant relaxation and a small CFL number.
I think it would be simplest to define a UDF which ramps the swirl from one value to the next over some number of iterations. I understand how to define the profile, but not how to access the iteration number in an UDF.
Any help is appreciated
Thanks
- Andy R
AndyR is offline   Reply With Quote
Old   August 26, 2010, 03:04
Max
coglione is on a distinguished road
N_ITER is the macro you are looking for. It retutns the number of iterations performed since you initialized your solution. As far as i know it works only in compiled udfs.
cheers
sam_paris and Ionut G like this.
coglione is offline   Reply With Quote
Old   March 6, 2018, 01:36
Smile Axisymmetric swirl-----space distribution for UDF
DENG Weriping
wpdeng is on a distinguished road
I simplified 3D geometry to 2D axisymmetry swirl. And I want to load a heat source about space distribution, but it's wrong when I use Cartesian coordinate system.
What should I do to deal with it?
wpdeng is offline   Reply With Quote
how to increase "Newton Pressure Iteration Limit" kus CFX 9 April 21, 2013 01:54
non stoppage of iteration alastormoody11 CFX 0 July 15, 2010 04:33
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
